Hello Guest it is November 13, 2026, 10:15:46 PM
Author Topic: Mach 3 not loading the entire toolpaths!!!  (Read 9808 times)
« on: January 20, 2012, 01:07:10 AM »
Hello,
Whenever I try to import a toolpath to Mach 3 it will only generate part of it! I have tried exporting the toolpath on different formats but no luck. It used to work fine, but this problem surfaced a week ago and I do not know how to fix it. Since only part of the toolpath is generated it is not completing the run. It seems to only happen with 3d relief rastering or z roughing. Other operations work fine.....
I use:
ArtCam Pro 8
Mach 3.043
Windows 7
The PC is a Core Duo with 4GB of Ram.
Any help is appreciated.
Re: Mach 3 not loading the entire toolpaths!!!
« Reply #1 on: January 20, 2012, 02:17:34 AM »
If your code is more than 500 lines you either do not have a licence or it is not installed correctly or lastly the licence you have is a pirated licence.
