Hello Guest it is October 20, 2026, 03:08:16 PM
Author Topic: Question on "Zerp World"  (Read 10719 times)
« on: January 15, 2012, 11:55:09 PM »
To the experts -
thank you for your kind advice. I never used the video tutorials until
you suggested that i do and now I realize how much further i could
have been if i had used the video tutorials. The one I have watched are comprehensive, easy yo understand
and very educational.
Just a question about " zero world"
If i zero world does it also reset the home position that was set with home x and home z ??
regards fred
Re: Question on "Zerp World"
« Reply #1 on: January 16, 2012, 05:03:50 AM »
The Zero World buttons, found on Turns manual screen, resets the axis position to 0 and will clear /remove any work offsets.
« Reply #2 on: January 16, 2012, 12:26:09 PM »
but does the "Home" position as set by set home remain untouched?
thanks Rich
« Reply #3 on: January 16, 2012, 05:40:58 PM »
The home position will be lost since by clicking the Zero World button you are telling Mach that the current position in Machine coordinates is now
at a different location. So you would need to define where your new home position is.  Home can be anywhere.  Think of it as cleaning everything and starting from scratch.
« Reply #4 on: January 17, 2012, 02:40:22 AM »
thanks Rich
regards from South africa
