Hello Guest it is November 22, 2026, 02:25:36 PM
Author Topic: Pitch issues threading on the lathe  (Read 8727 times)
« on: January 12, 2012, 11:34:19 AM »
I am running Mach3 Version R3.043.053
In the last few days I have installed on my lathe an opto coupler with an index attached to the spindle shaft.
I have done many tests before start threading.
The signal is fine and the RPM indication on the DRO is correct.
I have checked the speed with a digital tach that indicates the same speed.
Checks have been done at different speeds with the same results.
In the "Spindle Setup" I have the sync mode and speed averaging enabled.
So it seems that everything is OK.
Using the simple threading wizard I started a test threading 8mm x 1 10 mm long.
Everything worked fine and the pitch was correct measured with a thread pitch gauge.
I repeated the operation modifying only the pitch taking it at 1.25.
The final pitch this time was wrong measured again with thread pitch gauge.
I have tried many times with the same result.
Cutting another thread with a pitch = 0.5 it was correct.
I don't know where to look for to solve this issue.
Is there somebody having the same trouble?
« Last Edit: January 12, 2012, 11:47:09 AM by marius53 »
