Hello Guest it is November 13, 2026, 01:31:48 PM
Author Topic: external e stop requested newguy  (Read 25577 times)
« on: January 10, 2012, 04:45:09 PM »
sorry if this was asked before im new to the sight,i just started messing around with mach 3 and i plan on building my own cnc i have some cnc and machining back round and was playing around on mach to see what its like and it keeps telling me external e stop requested is there a way to shut this off i just want to mess with some g code and do the simulated program runs
Re: external e stop requested newguy
« Reply #1 on: January 10, 2012, 05:26:08 PM »
Go to config menu then Ports and Pins then Inputs then scroll to E-Stop and change the active state.
« Reply #2 on: January 10, 2012, 10:02:10 PM »
it keeps turning it self back on?
Offline mark4
  •  167 167
« Reply #3 on: January 10, 2012, 11:16:23 PM »
do you have a control hooked to the computer or just the computer
« Reply #4 on: January 10, 2012, 11:59:58 PM »
just the computer
« Reply #5 on: January 11, 2012, 01:49:34 AM »
You are changing the active state? or trying to disable the E-Stop?
If the former attach your xml and I will have a look, if the latter then that is correct as it is meant to be not possible to run without an E-Stop so Mach will not allow you to disable the E-Stop input.
« Reply #6 on: January 23, 2012, 03:53:15 PM »
so i bought one of these
http://www.ebay.com/itm/260932012571?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_5725wt_932
just hoping to see some stuff more before i sink some real money
and im still getting the e stop problem have a stepper motor hooked up and changed the e stop to pin 15 as shown in the picture on e bay trying to figure out the basics here any help would be appreciated.
« Reply #7 on: January 23, 2012, 05:00:25 PM »
Can you attach your xml please.
« Reply #8 on: December 25, 2016, 07:48:04 AM »
Hi having same problem estop requested tryed  setting to 2000 in top right on main page
Tryed setting active low that turns it of but then said limit switch activated dro runs but not motors turn
Please help need to get machine working again  thanks steve uk 07775604191
