Hello Guest it is October 21, 2026, 03:51:10 PM
Author Topic: how to modify a plug in?  (Read 15034 times)
Offline v tec
  •  31 31
« on: January 08, 2012, 06:53:36 AM »
hi, i would like modify this plug in:
http://www.machsupport.com/plugins/JCode.m3p
it s the jcode plug in
because it write only the xyz axis, and not the xyzabc axis
but i don t know how to do
and if someone know how to work this plug in, because i don t understand for record each xyzabc position line by line
Re: how to modify a plug in?
« Reply #1 on: January 08, 2012, 09:09:45 AM »
Modifying a plugin would require you to have the source code and I am not sure if Brian has released it or not.
Yopu may have more luck with the copycat wizard, I have not tried it but if it doesnt have access to the A B C DROs then you can likely change the button script in the wizard.
Offline v tec
  •  31 31
« Reply #2 on: January 08, 2012, 10:49:17 AM »
maybe we can suggest at brian, to add abc axis
to add  button
one for write in the code at the last line
one for insert the code between  line
if someone know brian
« Reply #3 on: January 08, 2012, 11:09:58 AM »
Brian is the guy that now writes Mach, he is a bit busy normally ;) If enough people wanted it then I would imagine it would go on the list of things to do but I am not sure it would be high on many peoples list of wants.
Offline v tec
  •  31 31
« Reply #4 on: January 08, 2012, 11:22:40 AM »
i understand, but how to help him?
« Reply #5 on: January 08, 2012, 11:35:09 AM »
Best thing to do would be send a request to andrew@machsupport.com and see if it gets on the list. It may be it is a very easy thing for Brian to modify or it may be it is a very hard thing, only Brian will know.
Offline v tec
  •  31 31
« Reply #6 on: January 08, 2012, 11:43:20 AM »
mail sent
the best for this plug in will
start a new file blank
adjust the position for all axis
click on a button for write all position with the good position
exemple
g0x10y5z8a-5b10z300
after continue to adjsut the axis, write the second line with jcode
etc....
and if you need to insert a line before the line *********, you can use an other button
with this plug in, you can program a arm robot, finger in the noze ^^
« Last Edit: January 08, 2012, 11:48:53 AM by v tec »
Offline v tec
  •  31 31
« Reply #7 on: January 08, 2012, 12:47:00 PM »
after test, copycat is fine, easy to use it
but only 3 axis
