Hello Guest it is October 23, 2026, 06:01:48 AM
Author Topic: Finding Motor Tuning Info in backed up directory???  (Read 20691 times)
« on: December 11, 2011, 08:06:09 PM »
Hey There,
I am running a Sherline 2000 series mill, and had my hard drive go down. I have a back up of the entire Mach 3 directory, but where the hell do I find the mototr tuning info?? Or how do I recreate it???
Any help would be greatly appreaciated.
Jim
AndersonPrototypes.com
Re: Finding Motor Tuning Info in backed up directory???
« Reply #1 on: December 12, 2011, 02:18:40 AM »
Did you find it? Was it successful?
JR.
« Reply #2 on: December 12, 2011, 03:11:22 AM »
If you look for the xml file that has the name of the profile you were using you can then just drop that into your new drives Mach3 folder and all your settings will be back.
« Reply #3 on: August 05, 2012, 01:49:15 PM »
Hey There,
After a hard drive failure, I am reloading the system. I had a copy of the XML from my machine manufacturer and pasted it in the Mach 3 folder. The problem is it doesn't seem t pick it up or something. Do I need to delete something first?
Any help please.
Jim
XML doesn't seem to work
« Reply #4 on: August 05, 2012, 08:35:39 PM »
Everyone on vacation today?? :D
Jim
« Reply #5 on: August 06, 2012, 01:59:57 AM »
Jim
Considering its taken you 8 months to respond to the help offered to your original post then maybe you will get a response in April 2013 ;)
« Reply #6 on: August 06, 2012, 07:14:57 PM »
Hood,
I guess I fiquered it out the last time and forgot to comment on that fact.
This is a different machine and I am pulling my hair out with this one. I still have not been able to get it to read the XML file that it did read the original installation. What could possibly be wrong? I have no back up for this XML as the hard drive failed and I assumed the orginal one would work again (that I had stored on another PC.)
As a side question, under PURCHASES, there are break out boards. What difference is there between the stock one and anyone of those boards. Would they offer better performance?
Thanks Jim
« Reply #7 on: August 07, 2012, 04:31:39 AM »
Attach your xml and I will have a look.
« Reply #8 on: August 07, 2012, 11:21:05 AM »
Hi Hood,
I am a little challenged by this forum, but working thru it.
I think I have attached the XML file. I am grateful for your assistance.
Jim
« Reply #9 on: August 07, 2012, 12:40:14 PM »
XML looks ok from first glance, are you choosing the correct one when starting Mach?
The post is set to a standard onboard port, if you are not using that then you may have the wrong address set.
