Hello
Guest
it is
September 28, 2026, 07:34:44 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
List of default hotkeys
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: List of default hotkeys (Read 15836 times)
Fred_evans
396
on:
December 09, 2011, 01:57:46 AM »
Hello everyone--
is there a list of the default hotkeys any where?
think of the trees-- use both sides of the computer paper
Carnoustie, Scotland
Re: List of default hotkeys
Reply #1 on:
December 09, 2011, 02:00:07 AM »
I think the customisation manual may have a list of the ascii numbers used, its been a while though so maybe I am remembering incorrectly.
Fred_evans
396
Reply #2 on:
December 09, 2011, 03:10:02 AM »
thanks Hood
Please give me the full name of the customization manual so I can google??
regards
fred
Reply #3 on:
December 09, 2011, 04:09:34 AM »
Just look at the top of the forum, support tab then doccumentation and t should be there, will be in the Mach2 section rather than Mach3 but most things are still relevant.
ger21
6,295
Reply #4 on:
December 09, 2011, 10:49:40 AM »
http://www.machsupport.com/MachCustomizeWiki/index.php?title=Standard_Hotkeys
Klaus1311
531
Reply #5 on:
December 10, 2011, 05:49:43 AM »
Hello
you can get all used hotkeys of a screen with MachScreen.
Load the screen, select menu View -> Hotkeys. The sort order can be chosen by clicking in the desired column header.
Klaus
The brain isn't a soap, it doesn't shrink when used.
Fred_evans
396
Reply #6 on:
December 10, 2011, 08:33:02 AM »
thanks Klaus-- is machscreen a seperate program- or is it part of the mach3 literaqture?
to the rest of you
thanks--
regards
fred evans
Klaus1311
531
Reply #7 on:
December 10, 2011, 08:58:11 AM »
Hey Fred,
MachScreen is a screen designer. You can download here
http://www.kd-dietz.com/klausphp/index_eng.html
Under projects you'll find some programs / plugins for Mach
Klaus
Print
Pages:
1
Go Up
« previous
next »
