Hello Guest it is November 22, 2026, 02:08:23 PM
Author Topic: List of default hotkeys  (Read 16445 times)
« on: December 09, 2011, 01:57:46 AM »
Hello everyone--
is there a list of the default hotkeys any where?
Re: List of default hotkeys
« Reply #1 on: December 09, 2011, 02:00:07 AM »
I think the customisation manual may have a list of the ascii numbers used, its been a while though so maybe I am remembering incorrectly.
« Reply #2 on: December 09, 2011, 03:10:02 AM »
thanks Hood
Please give me the full name of the customization manual so I can google??
regards
fred
« Reply #3 on: December 09, 2011, 04:09:34 AM »
Just look at the top of the forum, support tab then doccumentation and t should be there, will be in the Mach2 section rather than Mach3 but most things are still relevant.
« Reply #5 on: December 10, 2011, 05:49:43 AM »
Hello
you can get all used hotkeys of a screen with MachScreen.
Load the screen, select menu View -> Hotkeys. The sort order can be chosen by clicking in the desired column header.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #6 on: December 10, 2011, 08:33:02 AM »
thanks Klaus-- is machscreen a seperate program- or is it part of the mach3 literaqture?
to the rest of you
thanks--
regards
fred evans
« Reply #7 on: December 10, 2011, 08:58:11 AM »
Hey Fred,
MachScreen is a screen designer. You can download here http://www.kd-dietz.com/klausphp/index_eng.html.
Under projects you'll find some programs / plugins for Mach
Klaus
