Hello Guest it is November 22, 2026, 02:56:41 PM
Author Topic: Strategy for servo drive faults with Galil?  (Read 8944 times)
« on: December 08, 2011, 06:13:10 PM »
I have a Galil motion controller (DMC-4143) connected to Pacific Scientific servo drives for 3-axis CNC.  Each one of the servo drives (there's 4 of them, its a slaved gantry) has a fault output.  I want the system to stop anytime there's a fault on any of the four servo drives.  I would prefer not to use discrete logic to combine these outputs.  Is the best strategy to connect each of them to a seperate general purpose input on the Galil and somehow map those to e-stop?  Any guidance appreciated.
Re: Strategy for servo drive faults with Galil?
« Reply #1 on: December 08, 2011, 06:38:12 PM »
You are in the wrong section try the galil section
« Reply #2 on: December 09, 2011, 11:04:39 AM »
There is a General Abort input that can be configured with the CN command, if you want to save on inputs, you could parallel four open collector 2n7000 or a ULN2803 to combine into one output.
This input aborts motion and stops the program automatically .
Nosmo.
« Last Edit: December 09, 2011, 11:06:59 AM by NosmoKing »
