Hello Guest it is November 13, 2026, 09:47:45 AM
Author Topic: Y-axis not moving  (Read 34014 times)
Y-axis not moving
« on: December 06, 2011, 03:20:31 AM »
Hi l am new in this forum. I am a new worker hired by my boss to handle a new cnc machine he bought from China. We trying to use the machine for our jewelry project. The problem is l am very new in cnc machine, as well as Mach3. I received the machine a few days ago from China and try to fix up the machine. My problem now is no matter how hard l tried, the Y-axis will never move. There's no problem with my keyboard jogging,X and Z axis will move accordingly. I tried to applied a G-code, the machine move precisely except for Y-axis. Can anyone explain to me what is going on with my machine?    ???
Re: Y-axis not moving
« Reply #1 on: December 06, 2011, 03:34:37 AM »
Sadly a lot of the Chinese products sold are of questionable quality and often there is a hardware problem.
If you attach the xml I can take a look at it and see if the Mach configuration is correct, a link to info on the specific machine would also be helpful.
« Reply #2 on: December 06, 2011, 04:41:27 AM »
Thank you Hood, here is the link to the cnc machine: http://www.aliexpress.com/snapshot/103489479.html
  •  9,377 9,377
« Reply #3 on: December 06, 2011, 05:41:55 AM »
Hi Ben,
Your .xml file is in the Mach3 folder entitled Mach3Mill.xml or named after whatever profile you are running. Copy it, rename the copy to something like Bens.xml and post it. Hood can then check your Mach configuration and let's hope this is the problem  ;)
It may, at this stage, be worth checking with a continuity tester / multimeter that your parallel port cable is good and that pin#1 is connected to pin#1, pin#2 to pin#2. etc etc. with no shorts between pins.
« Reply #4 on: December 06, 2011, 06:15:51 AM »
Thank you Tweakie, l will post it soonest
« Reply #5 on: December 07, 2011, 02:16:43 AM »
Hi Tweakie, l am very new in cnc world, can you guide me on how to get my xml file?   ;D
  •  9,377 9,377
« Reply #6 on: December 07, 2011, 02:30:22 AM »
Hi Ben,
Obviously your PC directory structure will be configured differently but this is where my xml is located.
« Reply #7 on: December 07, 2011, 03:56:21 AM »
Hi Tweakie and Hood, is this is the xml code that you guys mentioned? I couldn't post all of it because already over the wording limit. Please be patience with me, l am a business student, not a mechanical student  :-[
- <profile>
- <Preferences>
  <PulseSpeed>0</PulseSpeed>
  <Profile>Mach3Mill</Profile>
  <Layout>1024.set</Layout>
  <FirstRun>1</FirstRun>
  <Units>0</Units>
  <Serial>1</Serial>
  <Port2Input>0</Port2Input>
  <GeckoMode>0</GeckoMode>
  <USBINPUTS>16</USBINPUTS>
  <USBOUTPUTS>16</USBOUTPUTS>
  <Port2On>0</Port2On>
  <Port1On>1</Port1On>
  <Port1Add>888</Port1Add>
  <Port2Add>632</Port2Add>
  <MaxCL>0</MaxCL>
  <MaxNC10>0</MaxNC10>
  <Motor0Active>1</Motor0Active>
  <Motor0DirNeg>0</Motor0DirNeg>
  <Motor0DirPort>1</Motor0DirPort>
  <Motor0DirPin>3</Motor0DirPin>
  <Motor0StepNeg>1</Motor0StepNeg>
  <Motor0StepPort>1</Motor0StepPort>
  <Motor0StepPin>2</Motor0StepPin>
  <Motor1Active>1</Motor1Active>
  <Motor1DirNeg>1</Motor1DirNeg>
  <Motor1DirPort>1</Motor1DirPort>
  <Motor1DirPin>6</Motor1DirPin>
  <Motor1StepNeg>1</Motor1StepNeg>
  <Motor1StepPort>1</Motor1StepPort>
  <Motor1StepPin>5</Motor1StepPin>
  <Motor2Active>1</Motor2Active>
  <Motor2DirNeg>0</Motor2DirNeg>
  <Motor2DirPort>1</Motor2DirPort>
  <Motor2DirPin>9</Motor2DirPin>
  <Motor2StepNeg>1</Motor2StepNeg>
  <Motor2StepPort>1</Motor2StepPort>
  <Motor2StepPin>8</Motor2StepPin>
  <Motor3Active>1</Motor3Active>
  <Motor3DirNeg>0</Motor3DirNeg>
  <Motor3DirPort>1</Motor3DirPort>
  <Motor3DirPin>17</Motor3DirPin>
  <Motor3StepNeg>0</Motor3StepNeg>
  <Motor3StepPort>1</Motor3StepPort>
  <Motor3StepPin>7</Motor3StepPin>
  <Motor4Active>0</Motor4Active>
  <Motor4DirNeg>0</Motor4DirNeg>
  <Motor4DirPort>0</Motor4DirPort>
  <Motor4DirPin>0</Motor4DirPin>
  <Motor4StepNeg>0</Motor4StepNeg>
  <Motor4StepPort>0</Motor4StepPort>
  <Motor4StepPin>0</Motor4StepPin>
  <Motor5Active>0</Motor5Active>
  <Motor5DirNeg>0</Motor5DirNeg>
  <Motor5DirPort>0</Motor5DirPort>
  <Motor5DirPin>0</Motor5DirPin>
  <Motor5StepNeg>0</Motor5StepNeg>
  <Motor5StepPort>0</Motor5StepPort>
  <Motor5StepPin>0</Motor5StepPin>
  <Motor6Active>0</Motor6Active>
  <Motor6DirNeg>0</Motor6DirNeg>
  <Motor6DirPort>0</Motor6DirPort>
  <Motor6DirPin>0</Motor6DirPin>
  <Motor6StepNeg>0</Motor6StepNeg>
  <Motor6StepPort>0</Motor6StepPort>
  <Motor6StepPin>0</Motor6StepPin>
  <Input0Active>1</Input0Active>
  <Input0Port>1</Input0Port>
  <Input0Pin>10</Input0Pin>
  <Input0Neg>1</Input0Neg>
  <Input0Emulated>0</Input0Emulated>
  <Input0EmuKey>0</Input0EmuKey>
  <Input1Active>1</Input1Active>
  <Input1Port>1</Input1Port>
  <Input1Pin>10</Input1Pin>
  <Input1Neg>1</Input1Neg>
  <Input1Emulated>0</Input1Emulated>
  <Input1EmuKey>0</Input1EmuKey>
  <Input2Active>0</Input2Active>
  <Input2Port>1</Input2Port>
  <Input2Pin>0</Input2Pin>
  <Input2Neg>0</Input2Neg>
  <Input2Emulated>0</Input2Emulated>
  <Input2EmuKey>0</Input2EmuKey>
  <Input3Active>0</Input3Active>
  <Input3Port>1</Input3Port>
  <Input3Pin>0</Input3Pin>
  <Input3Neg>0</Input3Neg>
  <Input3Emulated>0</Input3Emulated>
  <Input3EmuKey>0</Input3EmuKey>
  <Input4Active>0</Input4Active>
  <Input4Port>1</Input4Port>
  <Input4Pin>0</Input4Pin>
  <Input4Neg>0</Input4Neg>
  <Input4Emulated>0</Input4Emulated>
  <Input4EmuKey>0</Input4EmuKey>
  <Input5Active>0</Input5Active>
  <Input5Port>1</Input5Port>
  <Input5Pin>0</Input5Pin>
  <Input5Neg>0</Input5Neg>
  <Input5Emulated>0</Input5Emulated>
  <Input5EmuKey>0</Input5EmuKey>
  <Input6Active>0</Input6Active>
  <Input6Port>1</Input6Port>
  <Input6Pin>0</Input6Pin>
  <Input6Neg>0</Input6Neg>
  <Input6Emulated>0</Input6Emulated>
  <Input6EmuKey>0</Input6EmuKey>
  <Input7Active>0</Input7Active>
  <Input7Port>1</Input7Port>
  <Input7Pin>0</Input7Pin>
  <Input7Neg>0</Input7Neg>
  <Input7Emulated>0</Input7Emulated>
  <Input7EmuKey>0</Input7EmuKey>
  <Input8Active>0</Input8Active>
  <Input8Port>1</Input8Port>
  <Input8Pin>0</Input8Pin>
  <Input8Neg>0</Input8Neg>
  <Input8Emulated>0</Input8Emulated>
  <Input8EmuKey>0</Input8EmuKey>
  <Input9Active>0</Input9Active>
  <Input9Port>1</Input9Port>
  <Input9Pin>0</Input9Pin>
  <Input9Neg>0</Input9Neg>
  <Input9Emulated>0</Input9Emulated>
  <Input9EmuKey>0</Input9EmuKey>
  <Input10Active>0</Input10Active>
  <Input10Port>1</Input10Port>
  <Input10Pin>0</Input10Pin>
  <Input10Neg>0</Input10Neg>
  <Input10Emulated>0</Input10Emulated>
  <Input10EmuKey>0</Input10EmuKey>
  <Input11Active>0</Input11Active>
  <Input11Port>1</Input11Port>
  <Input11Pin>0</Input11Pin>
  <Input11Neg>0</Input11Neg>
  <Input11Emulated>0</Input11Emulated>
  <Input11EmuKey>0</Input11EmuKey>
  <Input12Active>0</Input12Active>
  <Input12Port>1</Input12Port>
  <Input12Pin>0</Input12Pin>
  <Input12Neg>0</Input12Neg>
  <Input12Emulated>0</Input12Emulated>
  <Input12EmuKey>0</Input12EmuKey>
  <Input13Active>0</Input13Active>
  <Input13Port>1</Input13Port>
  <Input13Pin>0</Input13Pin>
  <Input13Neg>0</Input13Neg>
  <Input13Emulated>0</Input13Emulated>
  <Input13EmuKey>0</Input13EmuKey>
  <Input14Active>0</Input14Active>
  <Input14Port>1</Input14Port>
  <Input14Pin>0</Input14Pin>
  <Input14Neg>0</Input14Neg>
  <Input14Emulated>0</Input14Emulated>
  <Input14EmuKey>0</Input14EmuKey>
  <Input15Active>0</Input15Active>
  <Input15Port>1</Input15Port>
  <Input15Pin>0</Input15Pin>
  <Input15Neg>0</Input15Neg>
  <Input15Emulated>0</Input15Emulated>
  <Input15EmuKey>0</Input15EmuKey>
  <Input16Active>0</Input16Active>
  <Input16Port>1</Input16Port>
  <Input16Pin>0</Input16Pin>
  <Input16Neg>0</Input16Neg>
  <Input16Emulated>0</Input16Emulated>
  <Input16EmuKey>0</Input16EmuKey>
  <Input17Active>0</Input17Active>
  <Input17Port>1</Input17Port>
  <Input17Pin>0</Input17Pin>
  <Input17Neg>0</Input17Neg>
  <Input17Emulated>0</Input17Emulated>
  <Input17EmuKey>0</Input17EmuKey>
  <Input18Active>0</Input18Active>
  <Input18Port>1</Input18Port>
  <Input18Pin>0</Input18Pin>
  <Input18Neg>0</Input18Neg>
  <Input18Emulated>0</Input18Emulated>
  <Input18EmuKey>0</Input18EmuKey>
  <Input19Active>0</Input19Active>
  <Input19Port>1</Input19Port>
  <Input19Pin>0</Input19Pin>
  <Input19Neg>0</Input19Neg>
  <Input19Emulated>0</Input19Emulated>
  <Input19EmuKey>0</Input19EmuKey>
  <Input20Active>0</Input20Active>
  <Input20Port>1</Input20Port>
  <Input20Pin>0</Input20Pin>
  <Input20Neg>0</Input20Neg>
  <Input20Emulated>0</Input20Emulated>
  <Input20EmuKey>0</Input20EmuKey>
  <Input21Active>0</Input21Active>
  <Input21Port>1</Input21Port>
  <Input21Pin>0</Input21Pin>
  <Input21Neg>0</Input21Neg>
  <Input21Emulated>0</Input21Emulated>
  <Input21EmuKey>0</Input21EmuKey>
  <Input22Active>0</Input22Active>
  <Input22Port>1</Input22Port>
  <Input22Pin>0</Input22Pin>
  <Input22Neg>0</Input22Neg>
  <Input22Emulated>0</Input22Emulated>
  <Input22EmuKey>0</Input22EmuKey>
  <Input23Active>0</Input23Active>
  <Input23Port>1</Input23Port>
  <Input23Pin>0</Input23Pin>
  <Input23Neg>0</Input23Neg>
  <Input23Emulated>0</Input23Emulated>
  <Input23EmuKey>0</Input23EmuKey>
  <Input24Active>0</Input24Active>
  <Input24Port>1</Input24Port>
  <Input24Pin>0</Input24Pin>
  <Input24Neg>0</Input24Neg>
  <Input24Emulated>0</Input24Emulated>
  <Input24EmuKey>0</Input24EmuKey>
  <Input25Active>1</Input25Active>
  <Input25Port>1</Input25Port>
  <Input25Pin>13</Input25Pin>
  <Input25Neg>0</Input25Neg>
  <Input25Emulated>0</Input25Emulated>
  <Input25EmuKey>0</Input25EmuKey>
  <Input26Active>0</Input26Active>
  <Input26Port>1</Input26Port>
  <Input26Pin>0</Input26Pin>
  <Input26Neg>0</Input26Neg>
  <Input26Emulated>0</Input26Emulated>
  <Input26EmuKey>0</Input26EmuKey>
  <Input27Active>0</Input27Active>
  <Input27Port>1</Input27Port>
  <Input27Pin>0</Input27Pin>
  <Input27Neg>0</Input27Neg>
  <Input27Emulated>0</Input27Emulated>
  <Input27EmuKey>0</Input27EmuKey>
  <Input28Active>0</Input28Active>
  <Input28Port>1</Input28Port>
  <Input28Pin>0</Input28Pin>
  <Input28Neg>0</Input28Neg>
  <Input28Emulated>0</Input28Emulated>
  <Input28EmuKey>0</Input28EmuKey>
  <Input29Active>0</Input29Active>
  <Input29Port>1</Input29Port>
  <Input29Pin>0</Input29Pin>
  <Input29Neg>0</Input29Neg>
  <Input29Emulated>0</Input29Emulated>
  <Input29EmuKey>0</Input29EmuKey>
  <Input30Active>0</Input30Active>
  <Input30Port>1</Input30Port>
  <Input30Pin>0</Input30Pin>
  <Input30Neg>0</Input30Neg>
  <Input30Emulated>0</Input30Emulated>
  <Input30EmuKey>0</Input30EmuKey>
  <Input31Active>0</Input31Active>
  <Input31Port>1</Input31Port>
  <Input31Pin>0</Input31Pin>
  <Input31Neg>0</Input31Neg>
  <Input31Emulated>0</Input31Emulated>
  <Input31EmuKey>0</Input31EmuKey>
  <Input32Active>0</Input32Active>
  <Input32Port>1</Input32Port>
  <Input32Pin>0</Input32Pin>
  <Input32Neg>0</Input32Neg>
  <Input32Emulated>0</Input32Emulated>
  <Input32EmuKey>0</Input32EmuKey>
  <Input33Active>0</Input33Active>
  <Input33Port>1</Input33Port>
  <Input33Pin>0</Input33Pin>
  <Input33Neg>0</Input33Neg>
  <Input33Emulated>0</Input33Emulated>
  <Input33EmuKey>0</Input33EmuKey>
  <Input34Active>0</Input34Active>
  <Input34Port>0</Input34Port>
  <Input34Pin>0</Input34Pin>
  <Input34Neg>0</Input34Neg>
  <Input34Emulated>0</Input34Emulated>
  <Input34EmuKey>0</Input34EmuKey>
  <Input35Active>0</Input35Active>
  <Input35Port>0</Input35Port>
  <Input35Pin>0</Input35Pin>
  <Input35Neg>0</Input35Neg>
  <Input35Emulated>0</Input35Emulated>
  <Input35EmuKey>0</Input35EmuKey>
  <Input36Active>0</Input36Active>
  <Input36Port>0</Input36Port>
  <Input36Pin>0</Input36Pin>
  <Input36Neg>0</Input36Neg>
  <Input36Emulated>0</Input36Emulated>
  <Input36EmuKey>0</Input36EmuKey>
  <Input37Active>0</Input37Active>
  <Input37Port>0</Input37Port>
  <Input37Pin>0</Input37Pin>
  <Input37Neg>0</Input37Neg>
  <Input37Emulated>0</Input37Emulated>
  <Input37EmuKey>0</Input37EmuKey>
  <Input38Active>0</Input38Active>
  <Input38Port>0</Input38Port>
  <Input38Pin>0</Input38Pin>
  <Input38Neg>0</Input38Neg>
  <Input38Emulated>0</Input38Emulated>
  <Input38EmuKey>0</Input38EmuKey>
  <Input39Active>0</Input39Active>
  <Input39Port>0</Input39Port>
  <Input39Pin>0</Input39Pin>
  <Input39Neg>0</Input39Neg>
  <Input39Emulated>0</Input39Emulated>
  <Input39EmuKey>0</Input39EmuKey>
  <Input40Active>0</Input40Active>
  <Input40Port>0</Input40Port>
  <Input40Pin>0</Input40Pin>
  <Input40Neg>0</Input40Neg>
  <Input40Emulated>0</Input40Emulated>
  <Input40EmuKey>0</Input40EmuKey>
  <Input41Active>0</Input41Active>
  <Input41Port>0</Input41Port>
  <Input41Pin>0</Input41Pin>
  <Input41Neg>0</Input41Neg>
  <Input41Emulated>0</Input41Emulated>
  <Input41EmuKey>0</Input41EmuKey>
  <Input42Active>0</Input42Active>
  <Input42Port>0</Input42Port>
  <Input42Pin>0</Input42Pin>
  <Input42Neg>0</Input42Neg>
  <Input42Emulated>0</Input42Emulated>
  <Input42EmuKey>0</Input42EmuKey>
  <Input43Active>0</Input43Active>
  <Input43Port>0</Input43Port>
  <Input43Pin>0</Input43Pin>
  <Input43Neg>0</Input43Neg>
  <Input43Emulated>0</Input43Emulated>
  <Input43EmuKey>0</Input43EmuKey>
  <Input44Active>0</Input44Active>
  <Input44Port>0</Input44Port>
  <Input44Pin>0</Input44Pin>
  <Input44Neg>0</Input44Neg>
  <Input44Emulated>0</Input44Emulated>
  <Input44EmuKey>0</Input44EmuKey>
  <Input45Active>0</Input45Active>
  <Input45Port>0</Input45Port>
  <Input45Pin>0</Input45Pin>
  <Input45Neg>0</Input45Neg>
  <Input45Emulated>0</Input45Emulated>
  <Input45EmuKey>0</Input45EmuKey>
  <Input46Active>0</Input46Active>
  <Input46Port>0</Input46Port>
  <Input46Pin>0</Input46Pin>
  <Input46Neg>0</Input46Neg>
  <Input46Emulated>0</Input46Emulated>
  <Input46EmuKey>0</Input46EmuKey>
  <Input47Active>0</Input47Active>
  <Input47Port>0</Input47Port>
  <Input47Pin>0</Input47Pin>
  <Input47Neg>0</Input47Neg>
  <Input47Emulated>0</Input47Emulated>
  <Input47EmuKey>0</Input47EmuKey>
  <Input48Active>0</Input48Active>
  <Input48Port>0</Input48Port>
  <Input48Pin>0</Input48Pin>
  <Input48Neg>0</Input48Neg>
  <Input48Emulated>0</Input48Emulated>
  <Input48EmuKey>0</Input48EmuKey>
  <Input49Active>0</Input49Active>
  <Input49Port>0</Input49Port>
  <Input49Pin>0</Input49Pin>
  <Input49Neg>0</Input49Neg>
  <Input49Emulated>0</Input49Emulated>
  <Input49EmuKey>0</Input49EmuKey>
  <Input50Active>0</Input50Active>
  <Input50Port>0</Input50Port>
  <Input50Pin>0</Input50Pin>
  <Input50Neg>0</Input50Neg>
  <Input50Emulated>0</Input50Emulated>
  <Input50EmuKey>0</Input50EmuKey>
  <Input51Active>0</Input51Active>
  <Input51Port>0</Input51Port>
  <Input51Pin>0</Input51Pin>
  <Input51Neg>0</Input51Neg>
  <Input51Emulated>0</Input51Emulated>
  <Input51EmuKey>0</Input51EmuKey>
  <Input52Active>0</Input52Active>
  <Input52Port>0</Input52Port>
  <Input52Pin>0</Input52Pin>
  <Input52Neg>0</Input52Neg>
  <Input52Emulated>0</Input52Emulated>
  <Input52EmuKey>0</Input52EmuKey>
  <Output0Active>0</Output0Active>
  <Output0Port>1</Output0Port>
  <Output0Pin>0</Output0Pin>
  <Output0Neg>0</Output0Neg>
  <Output1Active>1</Output1Active>
  <Output1Port>1</Output1Port>
  <Output1Pin>4</Output1Pin>
  <Output1Neg>1</Output1Neg>
  <Output2Active>0</Output2Active>
  <Output2Port>1</Output2Port>
  <Output2Pin>7</Output2Pin>
  <Output2Neg>0</Output2Neg>
  <Output3Active>0</Output3Active>
  <Output3Port>1</Output3Port>
  <Output3Pin>17</Output3Pin>
  <Output3Neg>0</Output3Neg>
  <Output4Active>0</Output4Active>
  <Output4Port>1</Output4Port>
  <Output4Pin>0</Output4Pin>
  <Output4Neg>0</Output4Neg>
  <Output5Active>0</Output5Active>
  <Output5Port>1</Output5Port>
  <Output5Pin>0</Output5Pin>
  <Output5Neg>0</Output5Neg>
  <Output6Active>0</Output6Active>
  <Output6Port>1</Output6Port>
  <Output6Pin>0</Output6Pin>
  <Output6Neg>0</Output6Neg>
  <Output7Active>0</Output7Active>
  <Output7Port>1</Output7Port>
  <Output7Pin>14</Output7Pin>
  <Output7Neg>0</Output7Neg>
  <Output8Active>0</Output8Active>
  <Output8Port>1</Output8Port>
  <Output8Pin>0</Output8Pin>
  <Output8Neg>0</Output8Neg>
  <Output9Active>0</Output9Active>
  <Output9Port>1</Output9Port>
  <Output9Pin>0</Output9Pin>
  <Output9Neg>0</Output9Neg>
  <Output10Active>0</Output10Active>
  <Output10Port>1</Output10Port>
  <Output10Pin>0</Output10Pin>
  <Output10Neg>0</Output10Neg>
  <Output11Active>0</Output11Active>
  <Output11Port>1</Output11Port>
  <Output11Pin>0</Output11Pin>
  <Output11Neg>0</Output11Neg>
  <Output12Active>0</Output12Active>
  <Output12Port>1</Output12Port>
  <Output12Pin>0</Output12Pin>
  <Output12Neg>0</Output12Neg>
  <Output13Active>0</Output13Active>
  <Output13Port>1</Output13Port>
  <Output13Pin>0</Output13Pin>
  <Output13Neg>0</Output13Neg>
  <Output14Active>0</Output14Active>
  <Output14Port>1</Output14Port>
  <Output14Pin>0</Output14Pin>
  <Output14Neg>0</Output14Neg>
  <Output15Active>0</Output15Active>
  <Output15Port>1</Output15Port>
  <Output15Pin>0</Output15Pin>
  <Output15Neg>0</Output15Neg>
  <Output16Active>0</Output16Active>
  <Output16Port>1</Output16Port>
  <Output16Pin>0</Output16Pin>
  <Output16Neg>0</Output16Neg>
  <Output17Active>0</Output17Active>
  <Output17Port>1</Output17Port>
  <Output17Pin>0</Output17Pin>
  <Output17Neg>0</Output17Neg>
  <Output18Active>0</Output18Active>
  <Output18Port>1</Output18Port>
  <Output18Pin>0</Output18Pin>
  <Output18Neg>0</Output18Neg>
  <Output19Active>0</Output19Active>
  <Output19Port>1</Output19Port>
  <Output19Pin>0</Output19Pin>
  <Output19Neg>0</Output19Neg>
  <Output20Active>0</Output20Active>
  <Output20Port>1</Output20Port>
  <Output20Pin>0</Output20Pin>
  <Output20Neg>0</Output20Neg>
  <Output21Active>0</Output21Active>
  <Output21Port>1</Output21Port>
  <Output21Pin>0</Output21Pin>
  <Output21Neg>0</Output21Neg>
  <Output22Active>0</Output22Active>
  <Output22Port>1</Output22Port>
  <Output22Pin>0</Output22Pin>
  <Output22Neg>0</Output22Neg>
  <Output23Active>0</Output23Active>
  <Output23Port>1</Output23Port>
  <Output23Pin>0</Output23Pin>
  <Output23Neg>0</Output23Neg>
  <Output24Active>0</Output24Active>
  <Output24Port>1</Output24Port>
  <Output24Pin>0</Output24Pin>
  <Output24Neg>0</Output24Neg>
  <Output25Active>0</Output25Active>
  <Output25Port>1</Output25Port>
  <Output25Pin>0</Output25Pin>
  <Output25Neg>0</Output25Neg>
  <Output26Active>0</Output26Active>
  <Output26Port>1</Output26Port>
  <Output26Pin>0</Output26Pin>
  <Output26Neg>0</Output26Neg>
  <Output27Active>0</Output27Active>
  <Output27Port>1</Output27Port>
  <Output27Pin>0</Output27Pin>
  <Output27Neg>0</Output27Neg>
  <Output28Active>0</Output28Active>
  <Output28Port>1</Output28Port>
  <Output28Pin>0</Output28Pin>
  <Output28Neg>0</Output28Neg>
  <Output29Active>0</Output29Active>
  <Output29Port>1</Output29Port>
  <Output29Pin>0</Output29Pin>
  <Output29Neg>0</Output29Neg>
  <Output30Active>0</Output30Active>
  <Output30Port>0</Output30Port>
  <Output30Pin>0</Output30Pin>
  <Output30Neg>0</Output30Neg>
  <Encoder0Active>0</Encoder0Active>
  <Encoder0APort>0</Encoder0APort>
  <Encoder0APin>0</Encoder0APin>
  <Encoder0BPort>0</Encoder0BPort>
  <Encoder0BPin>0</Encoder0BPin>
  <Encoder0Cal>1.000000</Encoder0Cal>
  <Encoder1Active>0</Encoder1Active>
  <Encoder1APort>0</Encoder1APort>
  <Encoder1APin>0</Encoder1APin>
  <Encoder1BPort>0</Encoder1BPort>
  <Encoder1BPin>0</Encoder1BPin>
  <Encoder1Cal>1.000000</Encoder1Cal>
  <Encoder2Active>0</Encoder2Active>
  <Encoder2APort>0</Encoder2APort>
  <Encoder2APin>0</Encoder2APin>
  <Encoder2BPort>0</Encoder2BPort>
  <Encoder2BPin>0</Encoder2BPin>
  <Encoder2Cal>1.000000</Encoder2Cal>
  <Encoder3Active>0</Encoder3Active>
  <Encoder3APort>0</Encoder3APort>
  <Encoder3APin>0</Encoder3APin>
  <Encoder3BPort>0</Encoder3BPort>
  <Encoder3BPin>0</Encoder3BPin>
  <Encoder3Cal>1.000000</Encoder3Cal>
  <Encoder4Active>0</Encoder4Active>
  <Encoder4APort>0</Encoder4APort>
  <Encoder4APin>0</Encoder4APin>
  <Encoder4BPort>0</Encoder4BPort>
  <Encoder4BPin>0</Encoder4BPin>
  <Encoder4Cal>1.000000</Encoder4Cal>
  <Encoder5Active>0</Encoder5Active>
  <Encoder5APort>0</Encoder5APort>
  <Encoder5APin>0</Encoder5APin>
  <Encoder5BPort>0</Encoder5BPort>
  <Encoder5BPin>0</Encoder5BPin>
  <Encoder5Cal>1.000000</Encoder5Cal>
  <Encoder6Active>0</Encoder6Active>
  <Encoder6APort>0</Encoder6APort>
  <Encoder6APin>0</Encoder6APin>
  <Encoder6BPort>0</Encoder6BPort>
  <Encoder6BPin>0</Encoder6BPin>
  <Encoder6Cal>1.000000</Encoder6Cal>
  <Encoder7Active>0</Encoder7Active>
  <Encoder7APort>0</Encoder7APort>
  <Encoder7APin>0</Encoder7APin>
  <Encoder7BPort>0</Encoder7BPort>
  <Encoder7BPin>0</Encoder7BPin>
  <Encoder7Cal />
  <Configured>1</Configured>
  <SlavePrim>0</SlavePrim>
  <Slave>-1</Slave>
« Reply #8 on: December 07, 2011, 04:10:14 AM »
Actually you'll want to upload the actual file using the "Additional Options" arrow at the bottom of the reply box on the reply page when you reply.
You'll click the arrow and use the attachments area to upload the xml.
Be sure to make a copy of your xml file and rename it to something like Ben1977xml.xml to be sure it will load on this forum as the name has to be unique or the forum will not accept it.
« Reply #9 on: December 07, 2011, 08:31:27 AM »
Please help me, urgent  :'(
