Hello Guest it is November 23, 2026, 09:43:37 PM
Author Topic: Incomplete Gcode load  (Read 25402 times)
« on: December 04, 2011, 10:22:37 PM »
Hi
I am new to this area but know software however am at a loss with this.
I make a file in Lazycame to route  'JB' I do everything that is outlined in the videos and manuals, however when I load the Gcade into Mach3 only part of the lettering is loaded.
Has anyoneone elese had this problem and does anyone know what I am doing wrong?
JOHN
  •  9,378 9,378
Re: Incomplete Gcode load
« Reply #1 on: December 05, 2011, 01:09:07 AM »
Hi John,
If you are using the demo (unlicensed) version of Mach there is a 500 line limit on the code. There are some code examples you can use for testing purposes here http://www.machsupport.com/forum/index.php/topic,18345.0.html
« Reply #2 on: December 05, 2011, 04:44:26 AM »
I tried them Thanks they worked fine.  But I just tried doing a J and there was only 250 lines and only half the J was there in mach3.
Would it be I am missing something in the chain set up or something like that?
Been at it for ages and at a loss. I fresh mind is needed I think lol
JOHN
  •  9,378 9,378
« Reply #3 on: December 05, 2011, 04:56:00 AM »
Hi John,
Perhaps a look through the lazy cam manual http://www.machsupport.com/forum/index.php/topic,12078.0.html may be helpful (I seldom use lazy cam so am no expert here).
« Reply #4 on: December 05, 2011, 05:05:40 AM »
Post the DXF file for the J.
« Reply #5 on: December 05, 2011, 03:14:08 PM »
Rich
As requested
JOHN
« Reply #6 on: December 05, 2011, 03:58:22 PM »
You posted the gcode file and not the dxf, but irrelevant, the file loads in Mach ( 1366 lines of code).
I attached a pic of the code backplotted into CAD and loaded in MACH.
Post the dxf file for the "J" that you only got half of in Mach.
« Reply #7 on: December 05, 2011, 04:23:07 PM »
Rich
I used LAzy cam to make the J. Used the drag feature. I have added the Lcam file.
JOHN
« Reply #8 on: December 05, 2011, 04:34:04 PM »
Works fine here. Attached is a pic in LC and also in Mach. About 1411 lines but i did mutiple depth cuts.
« Reply #9 on: December 05, 2011, 04:34:50 PM »
Post your xml file.
