Hello Guest it is October 21, 2026, 02:03:31 AM
Author Topic: External E stop  (Read 63736 times)
Offline Fastest1
  •  920 920
  • Houston, TX
Re: External E stop
« Reply #30 on: March 04, 2012, 04:36:13 PM »
lockdown or beta?
Re: External E stop
« Reply #31 on: March 04, 2012, 04:54:39 PM »
lockdown i believe.
Re: External E stop
« Reply #32 on: March 05, 2012, 05:18:10 AM »
Only options provided under File tab....Load g code , Lazycam, CLose file, Exit
There is no option to import a DXF...... ???
Click the Help tab and then About ......, what version does it say you are using?
« Last Edit: March 05, 2012, 05:21:20 AM by RICH »
Offline FJC
  •  1 1
Re: External E stop
« Reply #33 on: March 07, 2012, 09:26:30 AM »
The 540 drive I have requires that pulse pump be set active during reset on the general conf. in order to clear resets.
Re: External E stop
« Reply #34 on: March 19, 2012, 09:49:27 PM »
my version is R3.034.022
Re: External E stop
« Reply #35 on: March 19, 2012, 09:51:23 PM »
correction R3.043.022*   typo
Re: External E stop
« Reply #36 on: March 25, 2012, 05:50:38 PM »
any ideas why the option for importation of dxf isnt present on my drop down menu?
Re: External E stop
« Reply #37 on: March 25, 2012, 07:25:44 PM »
moonrunner87,
That option, from very old versions of mach, was replaced by Lazycam.
Re: External E stop
« Reply #38 on: April 01, 2012, 01:37:47 PM »
i see. that makes sense. i have the lazycam option, it seemed fairly complicated but i have all the manuals, n will play with it more. reminds me of the fanuc cam programs i used in college to import n run 2d cad files.   is there a manual specifically for lazycam? i didnt see one labeled as such
Re: External E stop
« Reply #39 on: April 01, 2012, 06:44:23 PM »
Yes there is a nanual for LC and can be found in Members Docs.
