Hello Guest it is October 21, 2026, 09:55:43 AM
Author Topic: External E stop  (Read 63774 times)
External E stop
« on: December 03, 2011, 01:10:26 PM »
have an external e stop request that wont clear. tried all the solutions presented in previous threads (ex. going to inputs and modifying the condition), and the problem persists. any ideas?
Re: External E stop
« Reply #1 on: December 03, 2011, 03:36:04 PM »
Either you have a pin set wrong or you are getting noise on that pin.
If you attach your xml I can check your config to eliminate that.
Re: External E stop
« Reply #2 on: December 03, 2011, 07:01:06 PM »
i just tried it said i could not attach it becouse the file name has already been uploaded or something. i could email it i suppose
Re: External E stop
« Reply #3 on: December 04, 2011, 04:52:03 AM »
Just make a copy and rename it - most people add their name or some identifier to it, Doesn't really matter, it just has to be unique.
Re: External E stop
« Reply #4 on: December 04, 2011, 11:37:37 AM »
ok here is my xml
Re: External E stop
« Reply #5 on: December 04, 2011, 12:11:19 PM »
Do you have an E-Stop button fitted?
If you do is it normally closed type?
Re: External E stop
« Reply #6 on: December 04, 2011, 12:20:12 PM »
noexternal buttons or switches have been fitted. i dont believe the controller has one. it has two switches only, a power switch and a green switch. its a gecko g540
Re: External E stop
« Reply #7 on: December 04, 2011, 12:23:39 PM »
Ok then go to config menu then ports and pins then inputs, scroll down and change the active state of the E-Stop to active low.
Re: External E stop
« Reply #8 on: December 04, 2011, 12:39:38 PM »
i tried this already. however i just tried it again to the same effect. it allows me to uncheck the green check mark and clear the active state of the e stop. then when i click apply, and ok and exit out of pins and ports the error is still flashing. down on the message bar it reads "reconfiguration estop". if i click reset. it then reads "external e stop" again and continues flashing...
Re: External E stop
« Reply #9 on: December 04, 2011, 02:56:16 PM »
The green should be chosen if setting active low, in the xml you attached  it was not, it was a red cross.
What kind of hardware do you have (drive, breakout etc)
