Hello
Guest
it is
October 20, 2026, 09:40:47 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
External E stop
« previous
next »
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: External E stop (Read 63725 times)
moonrunner87
18
External E stop
on:
December 03, 2011, 01:10:26 PM »
have an external e stop request that wont clear. tried all the solutions presented in previous threads (ex. going to inputs and modifying the condition), and the problem persists. any ideas?
Carnoustie, Scotland
Re: External E stop
Reply #1 on:
December 03, 2011, 03:36:04 PM »
Either you have a pin set wrong or you are getting noise on that pin.
If you attach your xml I can check your config to eliminate that.
moonrunner87
18
Re: External E stop
Reply #2 on:
December 03, 2011, 07:01:06 PM »
i just tried it said i could not attach it becouse the file name has already been uploaded or something. i could email it i suppose
Sargon
99
Re: External E stop
Reply #3 on:
December 04, 2011, 04:52:03 AM »
Just make a copy and rename it - most people add their name or some identifier to it, Doesn't really matter, it just has to be unique.
moonrunner87
18
Re: External E stop
Reply #4 on:
December 04, 2011, 11:37:37 AM »
ok here is my xml
Re: External E stop
Reply #5 on:
December 04, 2011, 12:11:19 PM »
Do you have an E-Stop button fitted?
If you do is it normally closed type?
moonrunner87
18
Re: External E stop
Reply #6 on:
December 04, 2011, 12:20:12 PM »
noexternal buttons or switches have been fitted. i dont believe the controller has one. it has two switches only, a power switch and a green switch. its a gecko g540
Re: External E stop
Reply #7 on:
December 04, 2011, 12:23:39 PM »
Ok then go to config menu then ports and pins then inputs, scroll down and change the active state of the E-Stop to active low.
moonrunner87
18
Re: External E stop
Reply #8 on:
December 04, 2011, 12:39:38 PM »
i tried this already. however i just tried it again to the same effect. it allows me to uncheck the green check mark and clear the active state of the e stop. then when i click apply, and ok and exit out of pins and ports the error is still flashing. down on the message bar it reads "reconfiguration estop". if i click reset. it then reads "external e stop" again and continues flashing...
Re: External E stop
Reply #9 on:
December 04, 2011, 02:56:16 PM »
The green should be chosen if setting active low, in the xml you attached it was not, it was a red cross.
What kind of hardware do you have (drive, breakout etc)
Print
Pages:
1
2
3
4
5
Go Up
« previous
next »
