Hello Guest it is November 22, 2026, 07:42:32 AM
Author Topic: color of the display window  (Read 9280 times)
« on: December 03, 2011, 01:04:19 PM »
Hello All
Is there a way in which the default colors used in the toolpath display can be changed.
The position of my lathe in relation to the window in the room makes the default color
very difficult to see ( in fact when there is sun it is almost invisible)
thanks and beat regards
fred evans
Re: color of the display window
« Reply #1 on: December 03, 2011, 01:48:07 PM »
Config > Toolpath
You can change the colors of the lines, but Mach won't let you use some colors.
« Reply #2 on: December 04, 2011, 01:43:55 PM »
Thanks that helped!!
