Hello Guest it is November 13, 2026, 09:45:35 AM
Author Topic: rotate the toolpath display  (Read 17079 times)
« on: December 03, 2011, 01:00:13 PM »
Hello All
The manual says that i can rotate the toolpath display.
I can get it to zoom and i can get it to pan-
but how do i get it to rotate.
Re: rotate the toolpath display
« Reply #1 on: December 03, 2011, 01:57:10 PM »
Left click and drag in it. Hold down the left mouse button while dragging
« Reply #2 on: December 04, 2011, 01:23:23 PM »
I am trying-- but it just gets bigger or smaller ( no rotating)
sorry
fred
« Reply #3 on: December 04, 2011, 01:33:16 PM »
Normal mouse assignments are
Left  >>>   Oribital pan (rotate)
Center >>  ZOOM
Right   >> XY pan
Yours may be different . Try the other buttons one at a time.
« Reply #4 on: December 06, 2011, 09:26:32 AM »
sorry still doesnt rotate??
will have to work without it
best regards and thanks
« Reply #5 on: December 06, 2011, 12:09:51 PM »
Rotate was even present way back in Mach2 days so why you cant get it I dont know unless it is Turn you are trying to do it in?
« Reply #6 on: December 07, 2011, 07:01:29 PM »
I am using mach3 turn
regards fred
« Reply #7 on: December 08, 2011, 02:23:03 AM »
There is no rotate in Turn, no need as you see all from a profile in Turn, well thats if it displays correctly :D
« Reply #8 on: January 05, 2012, 10:26:02 AM »
thanks Hood -
Just needed to get a bit more comfortable with mach3 turn - so thats why i am only coming back to this now
I have found that the difference is that my left bouse button and the wheel do the same thing
could you tell me where and how to configure these buttons.
(  If its complicated and a lot of typeing if you would just point me to the section in the manual
and i will read it up myself)
regards fred
« Reply #9 on: January 05, 2012, 10:39:21 AM »
Its not complicated or a lot of typing ;) they are not configurable and Left mouse/drag does the same as scroll wheel  in Turn.
