Mach Discussion => General Mach Discussion => Topic started by: Fred_evans on December 03, 2011, 02:00:13 PM
Hello All
The manual says that i can rotate the toolpath display.
I can get it to zoom and i can get it to pan-
but how do i get it to rotate.
Left click and drag in it. Hold down the left mouse button while dragging
I am trying-- but it just gets bigger or smaller ( no rotating)
sorry
fred
Normal mouse assignments are
Left >>> Oribital pan (rotate)
Center >> ZOOM
Right >> XY pan
Yours may be different . Try the other buttons one at a time.
sorry still doesnt rotate??
will have to work without it
best regards and thanks
Rotate was even present way back in Mach2 days so why you cant get it I dont know unless it is Turn you are trying to do it in?
I am using mach3 turn
regards fred
There is no rotate in Turn, no need as you see all from a profile in Turn, well thats if it displays correctly :D
thanks Hood -
Just needed to get a bit more comfortable with mach3 turn - so thats why i am only coming back to this now
I have found that the difference is that my left bouse button and the wheel do the same thing
could you tell me where and how to configure these buttons.
( If its complicated and a lot of typeing if you would just point me to the section in the manual
and i will read it up myself)
regards fred
Its not complicated or a lot of typing ;) they are not configurable and Left mouse/drag does the same as scroll wheel in Turn.
