Hello Guest it is November 07, 2026, 11:26:34 AM
Author Topic: Motors not responding  (Read 44436 times)
Re: Motors not responding
« Reply #20 on: November 23, 2011, 11:00:25 AM »
Hello Tweakie, I agree,it will probably be something simple that is wrong.  I did not swap the hard drive on the pc's.
John
  •  9,375 9,375
« Reply #21 on: November 23, 2011, 11:16:19 AM »
How about using a spare axis - "A" for example (on the side of the PCB) and then set up your Mach ports and pins configuration to drive this axis as though it is the X Axis. ??
« Reply #22 on: November 23, 2011, 12:32:39 PM »
Hello Tweakie, Without the driver installed ,nothing responds.
John
« Reply #23 on: November 23, 2011, 08:03:02 PM »
Hello Tweakie,  Thank you very much for the link you sent for the Mach optimization txt. .  It worked excellent. I have everything up and running.I don't know exactly what part of the optimization made it work because I only did the following steps.6,7,11,12,16,20,21,22,23.Once again,thank you and I thank everyone for their help.
John
  •  9,375 9,375
« Reply #24 on: November 24, 2011, 01:10:31 AM »
Excellent news John, I am really pleased you have got it running.  :D
« Reply #25 on: November 24, 2011, 11:45:40 AM »
Hello Tweakie, Thanks again . The reason I posted the steps that I took was for anyone who might have the same problem.Mach3 should run on any Pc if they follow the steps listed. I tried it on 3 Pc's that wouldn't run Mach3 before and now they can run it.
  I wish everyone a Happy Thanksgiving.
John
« Reply #26 on: November 29, 2011, 01:42:33 PM »
According to your Mach3.xml PulseWidth is 0 (zero). It must be 1 to 15 microsecond. Config/Motor Tunning! Don't check DirLowActive in Motor Outputs. Must be red.
Regards!
Rudolf
« Reply #27 on: November 14, 2013, 06:28:56 PM »
need machx lisence and paperwork/instructions   help
  •  9,375 9,375
« Reply #28 on: November 15, 2013, 12:59:44 AM »
http://www.machsupport.com/help-learning/product-manuals/
http://www.machsupport.com/licensing/
« Reply #29 on: November 20, 2013, 02:17:40 PM »
Hi Tweekie, I have the same problem as John05 and not you sent him his reply was.
John
Is it possible to send me the same link to see if it sorts out my problem with the motors not responding, I to have had to change my PC and the new one runs Windows 7 the old system ran XP for several years without any problems
