Hello Guest it is November 13, 2026, 10:15:38 PM
Author Topic: Multidimensional arrays in Cypress Basic?  (Read 14396 times)
« on: November 12, 2011, 02:00:49 PM »
Hello all,
In reading the Cypress Basic (CB) reference manual I see the CB supports multidimensional  arrays. But I can not find the answer to my questions.
1) How do you Dim an empty two dimensional array?  Dim myarray ( , ) as integer    -does not work.
2) If you get a two dimensional array declared, how do you ReDim it?
Thanks for your time and advice
farmertom
Re: Multidimensional arrays in Cypress Basic?
« Reply #1 on: November 17, 2011, 05:18:59 AM »
AFAIK you cannot initialize an empty multi-dimensional array. and you cannot ReDim it either as ReDim only accepts 1 parameter.
You could use a single array to do the same job though. You just have to manage the array yourself.
e.g.
Sub Main
   Dim MultiArray() As Integer
   Dim I As Integer, J As Integer
   Dim Dim1 As Integer, Dim2 As Integer
   Dim1 = 3
   Dim2 = 3
   Call ReDimArray(MultiArray(), Dim1, Dim2)
   For I = 0 To 3
      For J = 0 To 3
         Call SetArray(MultiArray, I, J, I + J)
         Print GetArray(MultiArray, I, J)
      Next J
   Next I
End Sub
Function ReDimArray(ByRef MultiArray() As Integer, dim1 As Integer, dim2 As Integer)
   ReDim MultiArray(dim1 * dim2)
End Function
Function SetArray(ByRef MultiArray() As Integer, dim1 As Integer, dim2 As Integer, value As Integer)
   MultiArray(dim1 * dim2) = value
End Function
Function GetArray(ByRef MultiArray() As Integer, dim1 As Integer, dim2 As Integer) As Integer
   GetArray = MultiArray(dim1 * dim2)
End Function
« Reply #2 on: November 17, 2011, 05:34:20 AM »
Correction:
Dim DimSize1 As Integer, DimSize2 As Integer
Sub Main
   DimSize1 = 3
   DimSize2 = 3
   Call ReDimArray(MultiArray(), DimSize1, DimSize2)
   'insert dummy data
   For I = 0 To 8
      MultiArray(I) = I
   Next I
   For I = 0 To 2
      For J = 0 To 2
'         Call SetArray(MultiArray, I, J, I + J)
      Next J
   Next I
End Sub
Function ReDimArray(ByRef MultiArray() As Integer, loc1 As Integer, loc2 As Integer)
   ReDim MultiArray(loc1 * loc2)
End Function
Function SetArray(ByRef MultiArray() As Integer, loc1 As Integer, loc2 As Integer, value As Integer)
   MultiArray(loc1 + loc2 * DimSize1) = value
End Function
Function GetArray(ByRef MultiArray() As Integer, loc1 As Integer, loc2 As Integer) As Integer
   GetArray = MultiArray(loc1 + loc2 * DimSize2)
End Function
« Reply #3 on: November 17, 2011, 07:00:08 AM »
Sargon,
Thanks for the reply. I did eventually go with a one dimensional array, but your idea of indexing the second dimension is a great idea. I will use that in future programing. Too bad CB is so limited.  Thanks for the time and effort to reply to my post.
regards
farmertom
« Reply #4 on: December 19, 2011, 06:57:46 AM »
Arrays should be initialized some values, we cannot left blank, whether it is a multidimensional array or one dimensional array.
« Reply #5 on: December 19, 2011, 06:10:57 PM »
The question pertained to resizing a multidimensional array. Initializing it wouldn't help accomplish this.
