Mach Discussion => VB and the development of wizards => Topic started by: farmertom on November 12, 2011, 03:00:49 PM
Hello all,
In reading the Cypress Basic (CB) reference manual I see the CB supports multidimensional arrays. But I can not find the answer to my questions.
1) How do you Dim an empty two dimensional array? Dim myarray ( , ) as integer -does not work.
2) If you get a two dimensional array declared, how do you ReDim it?
Thanks for your time and advice
farmertom
AFAIK you cannot initialize an empty multi-dimensional array. and you cannot ReDim it either as ReDim only accepts 1 parameter.
You could use a single array to do the same job though. You just have to manage the array yourself.
e.g.
Sub Main
Dim MultiArray() As Integer
Dim I As Integer, J As Integer
Dim Dim1 As Integer, Dim2 As Integer
Dim1 = 3
Dim2 = 3
Call ReDimArray(MultiArray(), Dim1, Dim2)
For I = 0 To 3
For J = 0 To 3
Call SetArray(MultiArray, I, J, I + J)
Print GetArray(MultiArray, I, J)
Next J
Next I
End Sub
Function ReDimArray(ByRef MultiArray() As Integer, dim1 As Integer, dim2 As Integer)
ReDim MultiArray(dim1 * dim2)
End Function
Function SetArray(ByRef MultiArray() As Integer, dim1 As Integer, dim2 As Integer, value As Integer)
MultiArray(dim1 * dim2) = value
End Function
Function GetArray(ByRef MultiArray() As Integer, dim1 As Integer, dim2 As Integer) As Integer
GetArray = MultiArray(dim1 * dim2)
End Function
Correction:
Dim DimSize1 As Integer, DimSize2 As Integer
Sub Main
DimSize1 = 3
DimSize2 = 3
Call ReDimArray(MultiArray(), DimSize1, DimSize2)
'insert dummy data
For I = 0 To 8
MultiArray(I) = I
Next I
For I = 0 To 2
For J = 0 To 2
' Call SetArray(MultiArray, I, J, I + J)
Next J
Next I
End Sub
Function ReDimArray(ByRef MultiArray() As Integer, loc1 As Integer, loc2 As Integer)
ReDim MultiArray(loc1 * loc2)
End Function
Function SetArray(ByRef MultiArray() As Integer, loc1 As Integer, loc2 As Integer, value As Integer)
MultiArray(loc1 + loc2 * DimSize1) = value
End Function
Function GetArray(ByRef MultiArray() As Integer, loc1 As Integer, loc2 As Integer) As Integer
GetArray = MultiArray(loc1 + loc2 * DimSize2)
End Function
Sargon,
Thanks for the reply. I did eventually go with a one dimensional array, but your idea of indexing the second dimension is a great idea. I will use that in future programing. Too bad CB is so limited. Thanks for the time and effort to reply to my post.
regards
farmertom
Arrays should be initialized some values, we cannot left blank, whether it is a multidimensional array or one dimensional array.
The question pertained to resizing a multidimensional array. Initializing it wouldn't help accomplish this.
