Hello Guest it is November 01, 2026, 10:12:31 AM
Author Topic: comments LC 2.00.031  (Read 11160 times)
Offline Psad
  •  82 82
« on: December 21, 2006, 07:19:25 AM »
I just downloaded this version, i like the new features but have a few comments.
1) I specify a tool on a layer in LC, tool change appears in Mach3 G-code but when i run the toolpath test the tool offsets don't work .
Yes i checked to see that both tools are defined in M3.
2) I created a new layer in LC and moved all my drill holes to that layer.
exported to M3.  when i imported it back in from M3 to LZ the drill layer disappeared.
3) just being picky.  When you start moving chains to a new layer the default should be whatever the last layer choice was.
EX i define a new layer for drill.  everytime i go to another hole to move to the new layer i have to scroll down and fine drill layer.
stupid me I've fat fingered the mouse and messed up a couple of time.
Your products are great keep up the good work.
Offline Psad
  •  82 82
Re: comments LC 2.00.031
« Reply #1 on: December 21, 2006, 07:42:26 AM »
It appears that auto clean is the issue in #2.  i can create a drill layer and move all holes to it.  but if i hit autoclean the holes move back to the original layer and that new layer disappears.
I'd like the ability to remove an entire layer if I want to
Also I'd like to see the ability to rename a new layer after I've misspelled it originally
Offline Psad
  •  82 82
« Reply #2 on: December 21, 2006, 07:58:45 AM »
I now have my tool offsets working - don't know why they did not before ???
« Reply #3 on: December 21, 2006, 09:21:59 AM »
To delete a layer right click on the layer in the layer tree and select delete... Tell me if that works
Brian
www.newfangledsolutions.com
www.machsupport.com
