Hello Guest it is November 13, 2026, 09:37:45 AM
Author Topic: roadrunner  (Read 14248 times)
Offline skaha
  •  57 57
  • My first attempt
roadrunner
« on: December 20, 2006, 06:05:31 PM »
Hi, guys, just got my machine to run finally, tried cutting the roadrunner for test, machine quits part way through program, always at same spot, is this because I am using demo version or a problem? Also what is your opinion on using the optimization settings, I have some pretty long and ugly lines when I run the driver test?
Thanks for any direction you can give.
Nooby
Re: roadrunner
« Reply #1 on: December 20, 2006, 06:23:39 PM »
What line of code is it stopping on. The demo will run 1000 lines. The optimization is a good thing. I don't run anything other than the bare necessities on my mill PC.
Did you get your steps per sorted?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: roadrunner
« Reply #2 on: December 20, 2006, 06:25:36 PM »
Run the file again and on the Mach 'Program' screen there is a line counter, is it stopping at 1000?
If so its the demo limit.
Graham.
Offline skaha
  •  57 57
  • My first attempt
Re: roadrunner
« Reply #3 on: December 20, 2006, 06:39:05 PM »
Thanks for the comeback, I will try it again and see what line it quits on, I don't think it would be anywhere near 1000, I am still trying to grasp table settings etc. Yes I did enter the steps as you suggested Brett, that part seems to work fine.
Terry
Offline skaha
  •  57 57
  • My first attempt
Re: roadrunner
« Reply #4 on: December 20, 2006, 06:58:02 PM »
Graham your absolutely right, it stopped on line 1000, thats amazing how many lines it went thru.
Terry
Re: roadrunner
« Reply #5 on: December 22, 2006, 09:06:35 PM »
I am new to this I have a ez-router and ran to the same thing when I first startred. I had to have my license to get past line 1000.
Max
