Hello Guest it is November 22, 2026, 07:16:28 AM
Author Topic: acceleration data table  (Read 11133 times)
« on: October 29, 2011, 06:53:51 AM »
hello all
in some cnc software's, the acceleration data can be seen and modified. in mach3 we can see the same on config >> motor tuning.
is it possible to see the data which we save after setting the acceleration deceleration ramps?
regards
marker
Re: acceleration data table
« Reply #1 on: October 29, 2011, 09:58:08 AM »
XaccelValue = GetParameter(accelerationX)
« Reply #2 on: October 29, 2011, 02:28:55 PM »
dear friend
i didn't get you.
can you just explain the same?
what my question is can we see the integer value of steps of acceleration value?
regrads
marker
« Reply #3 on: October 29, 2011, 05:15:28 PM »
GetParameter(accelerationX) gives you the MAX accel settings you applied in the config screen. They are always the same once set.
Mach will not exceed that value but it can use a lesser value to coordinate feedrates on moves.
IF you are asking if you have access to what MACH3 is actually using at any given time ? Then the answer is no for the normal access. BUT I do believe you can get that info from a plugin as the plugin interface has that data available.
