Hello Guest it is October 20, 2026, 10:48:20 PM
Author Topic: drives will not reverse  (Read 11905 times)
« on: October 23, 2011, 12:45:30 PM »
I can jog in one direction only.  I replaced the BOB (DB25) recently and i also replaced my computer because the mother board was fried..  The Y  would reverse for a while   but when I made some changes it will work only one way now.  All seems ok in the program but may not be.  Help  Help
Re: drives will not reverse
« Reply #1 on: October 23, 2011, 02:00:59 PM »
Either bad wiring  for the Dir pins, bad bob  or you do not have the correct pins or ports assigned for the Dir pins.
« Reply #2 on: October 23, 2011, 05:02:27 PM »
I have all axis working in both directions Now ..except the X  axis.     I have checked and rechecked ports and pins setup  and  all checked to specs.  I was wondering if one wire is wrong on the bob. It maybe something simple.  Help
« Reply #3 on: October 24, 2011, 02:05:31 AM »
If you have a spare output on the BOB rewire the X Dir to it and re-assign in Ports and Pins, Motor Outputs to that pin and see if it helps.
« Reply #4 on: October 24, 2011, 02:42:27 PM »
Thanks for the help... It worked.  I changed the wires on BOB for the X dr.  from  2 and 3   to  8 and 9 :)
« Reply #5 on: October 24, 2011, 03:30:46 PM »
:) good you got it :)
