Hello Guest it is November 13, 2026, 08:05:02 PM
Author Topic: hardinge chnc 1 retrofit  (Read 10015 times)
« on: October 11, 2011, 10:47:32 PM »
Hi  every one  ihave a hardinge chnc 1 precsion  1986  i want to change over to mach3 but this machine has  air driven  collet,part shute, parting off tool and
tool changer it is 240 volt  3 phase . I have  researched and i think going to use some parts from cnc4pc but can any one tell me what   XML and  other softwear will be  needed to make this work.
p.s.   i can do the  wiring and  mechanical that is easy hard stuff is COMPUTER PROGRAMS plug and play is fine so please keep it simple thanks :'(
thanks for any help
Re: hardinge chnc 1 retrofit
« Reply #1 on: October 12, 2011, 04:40:20 AM »
You are likely going to need something like a PLC to get all the I/O you will require. Have a look in the ShowNtell section as a few people have done the Hardinge.
