Mach Discussion => General Mach Discussion => Topic started by: hornby chopper on October 11, 2011, 11:47:32 PM
Hi every one ihave a hardinge chnc 1 precsion 1986 i want to change over to mach3 but this machine has air driven collet,part shute, parting off tool and
tool changer it is 240 volt 3 phase . I have researched and i think going to use some parts from cnc4pc but can any one tell me what XML and other softwear will be needed to make this work.
p.s. i can do the wiring and mechanical that is easy hard stuff is COMPUTER PROGRAMS plug and play is fine so please keep it simple thanks :'(
thanks for any help
You are likely going to need something like a PLC to get all the I/O you will require. Have a look in the ShowNtell section as a few people have done the Hardinge.
