Hello Guest it is November 12, 2026, 06:12:45 PM
Author Topic: Help! Servo turns CW only with SS  (Read 13910 times)
« on: October 03, 2011, 04:57:24 PM »
Hi everyone,
I just bought a SS last week and hooked up one servo today to test it. I`m using a C11G bob, G320x drivers and now the SS.
I`ve connected everything and tunned as a X axis, but no matter wich direction I jog, the servo only spins CW. I press the left arrow and it spins CW, I press the right arrow and it spins CW anyway...
Can anyone help me?
I`ve tested the C11G bob without the SS once and it worked ok, although not so smooth.
Thanks.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Help! Servo turns CW only with SS
« Reply #1 on: October 03, 2011, 07:24:18 PM »
Sounds like you are missing the direction signal. Could be a configuration issue in Mach or it could be a wiring issue. Use a volt meter to measure the voltage on the direction signal, it should change from around 0V to around 5V when you change the direction your jogging.
Happy machining , Jeff Birt
« Reply #2 on: October 03, 2011, 09:52:00 PM »
I switched the driver and motor to test if it had something to do with them, but no success. Even installed Mach on another computer but the problem persisted.
Can you tell which Mach3 configuratio I could try changing to fix this?
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #3 on: October 04, 2011, 09:38:28 AM »
You need to measure the voltage at the direction pin on your BOB first. This will tell you where the problem lies.
« Reply #4 on: October 04, 2011, 08:15:52 PM »
problem solved!!
The cause was a wrong wiring to the common terminal.
Thanks for the help, Jeff.
