Hello Guest it is November 23, 2026, 11:31:47 AM
Author Topic: where are my programs?  (Read 11272 times)
« on: December 16, 2006, 11:13:37 AM »
ok simple one. I know I read this but I cant find it. when I open the editor and write a program. then save. when I return to the program run screen and try and load the file I just wrote i cant seem to find it. open the editor, Its right there. go back and try and load it. no dice. what format do i have to save it in, in order for Mach3 to see it.
 :P
Re: where are my programs?
« Reply #1 on: December 16, 2006, 11:34:30 AM »
Not sure what all you can save them in but I use the .tap file extension.
Offline Scott
  •  140 140
« Reply #2 on: December 16, 2006, 12:45:31 PM »
I've found that if you don't have a return (enter) after your last line that they don't show up sometimes, or at least the last line won't show.
Scott
« Reply #3 on: December 16, 2006, 01:38:22 PM »
yeah Ive been through that. this is like some sort of format problem where when I try to load a saved program the mach software cant find it on my harddrive. even if I type the file name into the search prompt. I figured it out once but i cant figure out what I did.
