Hello Guest it is November 22, 2026, 02:27:54 PM
Author Topic: trouble with running g code  (Read 8242 times)
« on: September 14, 2011, 02:37:47 PM »
I ran the post processor in sheetcam to make the .tap file. When I try to run it It tells me I have an error in line 11. Files that use to work for me before now error also. I have been beating myself up trying to figure out what is wrong without any luck. Hopefully someone here can tell me what I am doing wrong. I am using a diy plasma set up with mach 3. I had it cutting four months ago, and now it errors on me.
I believe the location that errors is G023
Re: trouble with running g code
« Reply #1 on: September 14, 2011, 05:20:27 PM »
The post processor you used is for an ALLEN BRADELY controller pick one for MACH and it will run ok.
« Reply #2 on: September 14, 2011, 06:00:23 PM »
ahhhh......I feel dumb now....haha
