Hello Guest it is October 22, 2026, 08:40:35 PM
Author Topic: Home switches giving Estop  (Read 8464 times)
« on: September 05, 2011, 02:06:20 PM »
I have finally got round to putting home switches on my machine, but have a problem with the X and Y axes activating the Estop rather than homing. The Z axis seems fine and both the X and Y axes light up the led's on the diagnostics page. The actual Estop also works fine. Any body got a clue whats happening? ???
Re: Home switches giving Estop
« Reply #1 on: September 05, 2011, 03:31:02 PM »
Sounds like electrical noise, you could try setting a Debounce Interval of 2000 and see if that helps but best idea is to shield and properly ground the wires if you have not already done so.
« Reply #2 on: September 06, 2011, 03:06:53 PM »
Thanks Hood, that got it, all is now perfect!!!!!
