Hello Guest it is November 23, 2026, 07:25:07 PM
Author Topic: help needed with emco pc mill rebuild  (Read 26862 times)
Re: help needed with emco pc mill rebuild
« Reply #10 on: July 03, 2012, 01:56:25 PM »
i have got z and y axis move in one direction only put x axis in y axis to test if it works it does.
only z, y working x not working
if cannot get working will take borad out and shoot it these boards are a pain in the ass
I have the same board running, you can find alot more information at http://whatisacnc.com/driver-board/tb6560/
The pins on the Blue Board are a bit silly, but you will get it working.
The Pins need to be configured properly so the Motor receives the proper signal from the computer.
