Hello
Guest
it is
October 22, 2026, 07:11:53 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
version 3.043.022, skiping G 53 command's
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: version 3.043.022, skiping G 53 command's (Read 15657 times)
woffler
153
on:
August 31, 2011, 02:11:25 PM »
I downloaded the newest lock down version and it is skipping right through a G53Z0 command and a G53 X0Y0 command , i can provide file if need be.
Thank,s
Logged
Carnoustie, Scotland
Re: version 3.043.022, skiping G 53 command's
Reply #1 on:
August 31, 2011, 03:37:39 PM »
Attach the xml and code and I will see if I can replicate.
Logged
woffler
153
Reply #2 on:
August 31, 2011, 06:39:35 PM »
I keep getting a error message when it try to post with files . Try's to say i already uploaded the file's
Logged
woffler
153
Reply #3 on:
August 31, 2011, 06:48:31 PM »
Ok i renamed them let'see if it takes them.
Logged
woffler
153
Reply #4 on:
August 31, 2011, 06:52:18 PM »
It seems to be the M00 command at the end of the first tool that might be causing it MACH does not like M00! but it should still perform the G93 moves before stopping the program.
Logged
BR549
6,965
Reply #5 on:
August 31, 2011, 07:30:22 PM »
Remove the ";".
Logged
woffler
153
Reply #6 on:
August 31, 2011, 07:42:49 PM »
So that's the cause , i will have to find another post p , that does not put that in there or have one modified i may have another i will have to do further testing to see . Thank's Hood
Logged
Overloaded
4,923
Reply #7 on:
August 31, 2011, 07:46:52 PM »
......... and thanks to you as well TP,
Logged
BR549
6,965
Reply #8 on:
August 31, 2011, 07:55:32 PM »
The ; is a startpoint for a comment on a gcode line any thing to the right of it is sent to the message bar.
Old school, (;-) TP
Logged
Reply #9 on:
September 01, 2011, 01:03:32 AM »
No problem, glad I was of help
Think you meant to say
Thanks Terry
Logged
Print
Pages:
1
Go Up
« previous
next »
