Hello Guest it is November 14, 2026, 08:56:23 PM
Author Topic: Turn cutter comp work?  (Read 9625 times)
Offline DaOne
  •  236 236
« on: August 27, 2011, 11:57:48 PM »
Anyone know if cutter compensation (tip radius) works in turn? This is G40 - G42. If so maybe someone could give me an example because the fanuc code I have used doesn't appear to activate it. ???
Wes
Offline DaOne
  •  236 236
Re: Turn cutter comp work?
« Reply #1 on: August 28, 2011, 01:57:05 AM »
Well after searching the forums it looks like this still hasn't been fixed?  Maybe I am wrong? Maybe someone else can confirm this? If it is indeed screwed up still I will be removing the option from my screen set. Might see if I can figure out the math on this for the wizards. Anyone have any equations?
Offline DaOne
  •  236 236
« Reply #2 on: August 28, 2011, 02:22:35 AM »
I think I got the the math figured out so far... gonna give it a shot :)
