Hello Guest it is October 23, 2026, 06:18:33 AM
Author Topic: CSMIO/IP-S Ethernet Motion Controller (CNC)  (Read 118779 times)
« on: August 22, 2011, 05:29:18 AM »
CSMIO/IP-S Ethernet Motion Controller by CS-Lab Electronics (CNC)
DETAILS:
- PC connection via Ethernet.
- 6 axis controller.
- STEP frequency to 4MHz (differential outputs, very resistant to interference).
- Extremely stable machine speed control, thanks to the FPGA and advanced control algorithms.
- 32 digital inputs and 16 digital outputs (possibility to extend to 192 inputs / 96 outputs through additional modules).
- 4 analog inputs / 2 analog outputs (0-10V).
- All I/O are optically isolated, protected against short circuit, overheating, industry standard - 24V.
- Up to 3 slave axis support, machine geometry correction.
- Spindle inverter control through analog outputs.
- An extension of functionality through additional CanOpen modules. Currently available modules:
    CSMIO-IO – module of 16 additional inputs and 8 outputs (24V, optical isolation, overload protection). Possible to connect 10 of these modules.
    CSMIO-JOG – MPG connection modules – smooth control of the machine motion, automatic switching between speed and position mode.
    Work is underway on the CSMIO-SCAN module - to operate the laser scanner.
- Solid aluminium enclosure that discharge the heat very well and perfectly protects the electronic of the device.
- Comfortable Din-rail mounting.
- Succesfully developed software and the ability to update by yourself.
- The possibility to control all digital and analog signals by VisualBasic macros.
- Support for the FAULT signals of the servodrives – immediate machine stop In case of failure of any axis.
- RESET support for the axis drives.
- Readable LED controls on the front panel for easy installation.
In the next updates will be support for screws mapping and threading.
Re: CSMIO/IP-S Ethernet Motion Controller (CNC)
« Reply #1 on: August 26, 2011, 07:01:04 PM »
Looks an interesting controller, what price range is it as I could not find info on your site.
« Reply #2 on: August 26, 2011, 08:24:25 PM »
And where can we buy it from?
Also, the .zip file on the plugins page is not complete.
« Reply #3 on: August 29, 2011, 06:08:40 AM »
CSMIO/IP-S: price is 799 USD
CSMIO-LPT: 129 USD
Both products can be ordered by email: biuro@cs-lab.eu
The zip file on the  plugins page will be hopefully soon corrected. Complete file you can get on the company webpage:
CSMIO/IP-S: http://www.cs-lab.eu/artykul-11-CSMIOIPS_Download.html
CSMIO/LPT: http://www.cs-lab.eu/en/artykul-7-CSMIOLPT_Download.html
BR
« Reply #4 on: August 29, 2011, 09:11:29 AM »
Thanks, sounds reasonable for what it does, will have to watch this :)
« Reply #6 on: February 24, 2012, 07:05:58 AM »
New CSMIO controller in sale:
CSMIO/IP-M 4-axis Ethernet Motion Controller is "mini" CSMIO/IP-S version for not so advanced users, only for 210 Euro. It's good solution instead of LPT.
Regards
CS-LAB Team
www.cs-lab.eu
« Reply #7 on: April 19, 2012, 01:32:57 PM »
I was wondering whether it was possible to use one of the axis Step/Dir outputs and configure it as a Step/Dir spindle?
Also can the CSMIO/IP-M 4-axis  do lathe threading?
« Reply #8 on: April 24, 2012, 01:31:42 AM »
Lathe threading is in final test stage and is implemented by additional CSMIO-ENC module for spindle encoder connection.
With encoder we have very precise information about spindle position and speed. This week the system will be installed on a machine and will see how it works in practice  8)
Lathe threading will be available for “CSMIO/IP-S” version only.
Andrew
« Reply #9 on: April 24, 2012, 03:12:36 AM »
Ok thanks for the info, I look forward to hearing how things work out.
From your info above am I to assume this module will allow rigid tapping as well?
I dont see that module listed on the website, what is the cost of it?
Also with regards my other question, is it possible to use a Step/Dir axis output as a spindle rather than having to use the 0-10v output? If the spindle had been -10 to +10v I could use that but with the 0-10v it would mean I would need to invert the polarity via a relay which I dont really want to do, so using a step/dir axis output in spindle mode would be my ideal.
