Hello Guest it is November 13, 2026, 11:15:24 AM
Author Topic: Change speed and zero fifth axis  (Read 11332 times)
ericma
« on: December 13, 2006, 04:29:21 PM »
Friends:
I can not change the move speed by the F code and do not know how to zero the fifth axis.
A 5-axis CNC router is driven by Yaskawa servo motors and all axes are worked fine except the speed are too slow.
Thank you for any advice.
Eric Ma
Eric1ma@yahoo.com
Re: Change speed and zero fifth axis
« Reply #1 on: December 15, 2006, 07:03:45 AM »
You will need to aet up a 5axs screen set... check out the screen design section of the forum.
and the speed is a mix of Deg per min and In per min... If you look on the net there are a few places that talk about how to do that :( It is not a simple thing to do and most Cam systems should put out code to take care of that.
Brian
www.newfangledsolutions.com
www.machsupport.com
ericma
« Reply #2 on: December 15, 2006, 10:56:37 AM »
I will try the the 5th axis screen design
Eric
« Reply #3 on: December 16, 2006, 03:43:30 PM »
Tell me if you have any trouble
www.machsupport.com
