Hello
Guest
it is
October 20, 2026, 04:06:49 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Radius to end of arc differs from radius to start on line number ##
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Radius to end of arc differs from radius to start on line number ## (Read 57156 times)
Re: Radius to end of arc differs from radius to start on line number ##
Reply #20 on:
September 07, 2014, 06:57:55 PM »
Sunburned,
Your file backplots fine and Mach Mill runs it with no errors when I tried it out.
Post your xml file and someone will have a look.
Sunburned
5
Reply #21 on:
September 10, 2014, 06:19:34 PM »
Thanks for the help. My XML is attached. Please let me know if you need anything else. I had to rename it so i could post it.
Sunburned
5
Reply #22 on:
September 12, 2014, 07:29:50 PM »
bump
Sunburned
5
Reply #23 on:
September 16, 2014, 08:39:14 PM »
Just wanted to check on this. Any help would be great.
thanks
Reply #24 on:
September 17, 2014, 05:40:00 AM »
No errors reported here using your xml file.
Sunburned
5
Reply #25 on:
October 07, 2014, 12:47:38 PM »
I was hoping something would be found. If anyone has any other ideas I would be happy to try them out. Right now I have a very big and expensive paperweight.
Reply #26 on:
October 07, 2014, 03:59:15 PM »
Code works fine here. See pic ....
stirling
2,188
UK
Reply #27 on:
October 08, 2014, 02:49:35 AM »
The file you posted in reply #21 is not an XML file. It's a copy of the program MachXML.exe. Please post your xml PROFILE file. That's the one ending in .xml in your Mach3 folder with the same name as the profile you're using.
Razordance Torch Height Control
Print
Pages:
1
2
3
Go Up
« previous
next »
