Hello Guest it is November 13, 2026, 10:37:06 AM
Author Topic: G100 Plugin Status Update  (Read 14687 times)
« on: December 12, 2006, 10:55:18 PM »
I got my limit switches working and still crashes the axises!
any idea when this will be fixed???????
or should just plan on parallel port setup for now?
When the system is homing it  works fine.
Once homed ,
if you jog any axis manually
 It will overshoot and crash the axis
So the safe limits need fixing!
I can do without the softlimits but need safelimits!
Thanks for the good work
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
Re: G100 Plugin Status Update
« Reply #1 on: December 13, 2006, 01:32:13 AM »
Soft limits do not work on the g100 yet. Travel limits do work (limit switches). These are only there to cause an estop when they are hit, they don't limit the travel that is what soft limits do.
Chad
« Last Edit: December 13, 2006, 01:34:24 AM by chad »
« Reply #2 on: December 13, 2006, 11:21:16 AM »
So i need to have a second set of switches setup to cause an estop to keep this from happening
Is there a trick i can use to have the home switches function as the travel limits
the limit switches im using are optical
Offline chad
  •  361 361
« Reply #3 on: December 13, 2006, 07:09:38 PM »
Yes just asign the home and the limit that you would like to use the same pin number. Mach is smart enough to know when it is homing and use that as a home and all other times if it hits it will trigger a limit.
Chad
« Reply #4 on: December 14, 2006, 12:32:01 AM »
Cool
 I thought there would be a loop hole!
Programers think of everything  ;)
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Thanks for the quick reply
Offline chad
  •  361 361
« Reply #5 on: December 14, 2006, 01:14:11 AM »
np
Chad
