Hello Guest it is November 28, 2026, 06:21:21 AM
Author Topic: ActivateSignal(OUTPUT1)  (Read 17023 times)
« on: December 12, 2006, 06:35:09 PM »
Hi All,
First post so I hope I'm in the right spot.
I'm in the rudimentary stages of setting up a G100 and wanted to write a few (what I thought would be) "simple" macros to control the outputs.
I first went into config/ports & pins/output signals and enabled output 1, 2, 3, and 4.  I set 1,2, and 3 active low, which on the G100, activates the LED's so I have 3 LED's on and 1 off.
I went to Notepad and put in the single line: ActivateSignal(OUTPUT1). I tried 2, 3 and 4 as well.  I saved it as M101.m1s.
Needless to say, when run in Mach3, the G100 was unimpressed.  It sat there unblinking.  What am I missing??
Walt
Re: ActivateSignal(OUTPUT1)
« Reply #1 on: December 12, 2006, 09:55:26 PM »
I thought this macro was too simple for even me to get wrong.
I had it in the wrong directory.
I'll just slink away now............
« Reply #2 on: December 15, 2006, 07:07:00 AM »
No problem! Nice to see that you fixed it  8)
www.newfangledsolutions.com
www.machsupport.com
