Hello Guest it is November 23, 2026, 11:57:49 PM
Author Topic: Does a PCMCIA Parallel card function with Mach3?  (Read 10108 times)
« on: August 12, 2011, 08:31:37 AM »
I have Mach3 running with one parallel port running on a notebook without any problems (after buffering the port)
I want extend the input capacity of my system, can any body confirm if a PCMCIA Parallel adapter does function with Mach3?
In case of not compatible, is there an other solution to provide a 2nd parallel port?
marcberv
Re: Does a PCMCIA Parallel card function with Mach3?
« Reply #1 on: August 12, 2011, 10:41:52 AM »
MOst do fine.
« Reply #2 on: August 12, 2011, 07:00:10 PM »
I use two of them in my Desk Top with GECKO 540s one for mill other for lathe
