Hello Guest it is October 14, 2026, 06:25:41 PM
Author Topic: how turn off the plasma air at the end of cut?  (Read 9768 times)
« on: August 02, 2011, 09:57:04 PM »
I have a cnc plasma table with a hypertherm powermax 65, there is a way to turn off the air at the end of the cut? i know this air is for cooling the nozzle but at the end of the cut i think is not necesary
Re: how turn off the plasma air at the end of cut?
« Reply #1 on: August 02, 2011, 11:06:50 PM »
The air flow control is part of the plasma unit. It needs to cycle when IT needs it.
« Reply #2 on: August 02, 2011, 11:15:16 PM »
yes but at the end of every work y have to pull the triger fast and release of the plasma gun for turn off the air, i have a manual torch, i try adding at the end of the g code an comand to turn on and off the torch for turn off te air but dont work
« Reply #3 on: August 02, 2011, 11:44:47 PM »
It would seem that you did not get the torch functions interfaced to the controller properly.
