Hello
Guest
it is
November 14, 2026, 06:19:59 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
spindle pwm pin assignment other then #2-#9?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: spindle pwm pin assignment other then #2-#9? (Read 9348 times)
qwerty2012
2
on:
July 29, 2011, 11:38:17 AM »
Can I use pin #1, #14, #16 or #17 for Spindle PWM output properly at 1KHz base Freq.?
pins #2-#9 are high speed output but I couldn't find any information about timing of other outputs of mach3 in the documents.
Thanks...
Logged
BR549
6,965
Re: spindle pwm pin assignment other then #2-#9?
Reply #1 on:
July 29, 2011, 04:21:05 PM »
Last I knew ALL output pins are HIGH speed. They can run at the kernal Freq.
Just a thought, (;-) TP
Logged
qwerty2012
2
Reply #2 on:
August 05, 2011, 02:15:44 AM »
thanks for your comment
Logged
Print
Pages:
1
Go Up
« previous
next »
