Mach Discussion => General Mach Discussion => Topic started by: qwerty2012 on July 29, 2011, 12:38:17 PM
Can I use pin #1, #14, #16 or #17 for Spindle PWM output properly at 1KHz base Freq.?
pins #2-#9 are high speed output but I couldn't find any information about timing of other outputs of mach3 in the documents.
Thanks...
Last I knew ALL output pins are HIGH speed. They can run at the kernal Freq.
Just a thought, (;-) TP
thanks for your comment
