Hello Guest it is November 13, 2026, 09:46:40 AM
Author Topic: Mach3 going off course of cut  (Read 48086 times)
« on: December 09, 2006, 12:07:25 AM »
I drew a little part in auto cad and then sent it to Lcam..Set it all up..Looked good when it displayed..Then sent it to Mach 3..It looks good in the display..Mach will be cutting just fine and then all of a sudden it goes wildly off course..you can see the proper blue lines before and then the yellow cut course in the display just goes wildly off course,and it goes crazy with the speeds too!! The router itself goes with this crazy line forgetting about limits for speed too...What is going on here??  Michael
Re: Mach3 going off course of cut
« Reply #1 on: December 09, 2006, 12:11:05 AM »
Can you post you code for us to look at?
« Reply #2 on: December 09, 2006, 12:19:35 AM »
I think I did it right..Let me see
« Reply #3 on: December 09, 2006, 12:27:03 AM »
It will cut all the drill points real easy and make all the circles..It goes over to the outside profile and start cutting fine...then it goes off..taking the mill with it...as the off course line is being drawn yellow on the screen,my mill screams trying to keep up..I don't know...when you line jog the code line by line it follows okay..Michael
« Reply #4 on: December 09, 2006, 01:12:24 AM »
I ran the thing again off line...same thing...
« Reply #5 on: December 09, 2006, 01:18:28 AM »
Michael,
    I don't know. I'm no Gcode guru like some of the others. Are those leadin, out moves? If they are rapids, ( G0 ) they will ignore the feed rates and run at max. Can you post your DWG. file? Different color lines represent something. I don't know what the green means.
« Reply #6 on: December 09, 2006, 01:30:09 AM »
The outside profile is a closed polyline...the circles are just circles..The outside rectangle is set up to cut up high,so it actually doesn't  cut anything on the machine..I just made it that way because that was the piece of scrap wood I had to make this piece..
« Reply #7 on: December 09, 2006, 02:00:13 AM »
Here is the code I get for the outside profile.
ialbazae
« Reply #8 on: December 09, 2006, 04:04:25 AM »
i think if you used lazycam to generate the code you didn't use autoclean
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #9 on: December 09, 2006, 04:52:58 AM »
Here is my version including the holes,
Updated 09/12/2006
Graham.
« Last Edit: December 09, 2006, 12:30:08 PM by Graham Waterworth »
