Hello
Guest
it is
October 23, 2026, 06:53:41 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
An answer to my motor stalling problem when reversing
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: An answer to my motor stalling problem when reversing (Read 6902 times)
steelman
7
on:
July 17, 2011, 10:14:15 PM »
I found that it was my backlash enabled causing my stalling problem when ERP listed several things as did others. When I disabled backlash, it started working fine. I found that I needed the backlash to make my machine accurate but couldnt make the stalling when reversed quit. Then I found an article that answered my problem. I dont know the guys name, but he had the same problem and recommended setting the shuttle speed from 1 to .500. I did and it worked. I ended setting it at .250 and it works great. I had no idea that this had anything to do with backlash settings. I hope this helps someone else with backlash problems. This setting is found under general configuration. Again, thanks to all who replied. What a great forum Thanks, Vincent
Logged
Print
Pages:
1
Go Up
« previous
next »
