Hello Guest it is November 13, 2026, 03:47:46 PM
Author Topic: Mach 3 Scaling Problem  (Read 46520 times)
Re: Mach 3 Scaling Problem
« Reply #10 on: January 27, 2016, 09:22:44 AM »
I have a problem where over 16 inches the actual span of a plasma cut part turns out to be about 15.96875.  so I am losing about 1/32 over 16"  This same error is also reflected in spacing between holes, so it is not a function of kerf width.  Should this be adjusted in Scale DROs, or is there a better way to do this?  I am concerned that if I make a correction here, running a code written by someone else will undo my correction and unnecessary scrap will be generated.  Please advise.
  •  9,377 9,377
« Reply #11 on: January 27, 2016, 09:49:53 AM »
An error like that would seem to indicate that you have not set your steps per unit correctly. On the settings page there is a button 'set steps per unit' click the button and follow the onscreen instructions to check your current settings.
