Hello Guest it is November 24, 2026, 12:35:31 PM
Author Topic: Setting up remote START, STOP, PAUSE buttons  (Read 35343 times)
Re: Setting up remote START, STOP, PAUSE buttons
« Reply #20 on: July 11, 2011, 08:10:34 PM »
When PCI card installed, it defaulted to LPT3
I have set it back to port 2, saved settings, and shut down MACH3
Now it actually works!
For some reason it was not updating the XML file?
Thanks again!
Eric
« Reply #21 on: July 11, 2011, 08:15:05 PM »
What windows names the port has no bearing on what Mach calls it. In Mach you have Port 1 and Port 2 for parallel ports and the address set for each is what Mach looks at. So windows could call it LPT 1 and LPT 400 if it wanted but as long as you have the correct address set in Mach it will be Port 1 and Port 2 as far as Mach is concerned.
The changes you make will take effect immediately after a reset but will only actually be written to the xml on a restart of Mach.
« Reply #22 on: July 11, 2011, 08:15:33 PM »
LPT3 is NOT Port3.
You get Two parallel Ports, and they are either assigned to Port1, or Port2. The LPT #'s don't mean anything to Mach3.
