Hello Guest it is November 13, 2026, 03:33:55 PM
Author Topic: how to setup motor parameter in Mach3 when I use service motor  (Read 11036 times)
as the topic :
thank you!
Re: how to setup motor parameter in Mach3 when I use service motor
« Reply #1 on: July 02, 2011, 03:46:27 AM »
If you are meaning servo motor then it is the encoder count you use for the steps per unit calculation.
Would need a lot more info to say more.
« Reply #2 on: July 03, 2011, 07:27:52 PM »
ok thank you
I want to know how to setup servo motor ,step by step, because I am a new user for mach3
« Reply #3 on: July 07, 2011, 06:16:14 AM »
You will have to give a lot more info for any help to be given.
Do your drives accept Step/Dir input?
 What line encoder do you have?
What RPM is the motor rated at?
 Any gearing between motor and screw?
Any electronic gearing in your drives?
What pitch of ballscrew?
