Hello Guest it is November 13, 2026, 12:46:10 PM
Author Topic: Long pierce delay  (Read 10964 times)
Long pierce delay
« on: June 30, 2011, 09:25:38 AM »
I'm having a problem with a delay in my pierce even when the pierce delay is set to 0.0 in Sheetcam.  I have a THC301d and it gets an arc ok signal immediately after the firing of the torch and there is still @ 2 sec of delay while no G04 Px.x shows in the code.  Anyone have any ideas?
Re: Long pierce delay
« Reply #1 on: June 30, 2011, 10:10:35 AM »
Not sure about how plasma works but could it have anything to do with spindle delay settings on General Config page/
« Reply #2 on: June 30, 2011, 10:51:19 AM »
BINGO!  Thanks for the tip, that fixed it.
« Reply #3 on: June 30, 2011, 10:54:06 AM »
you check this parameter if you set pierce delay to 0 in sheetcam :
Config / Port and pin /spindle setup /General parameters
Amir
**Even a clock that does not work is right twice a day**
« Reply #4 on: July 03, 2011, 06:33:33 AM »
Cool,
always wondered about that but it hadn't bothered me enough to ask.
Thanks.
