Hello Guest it is November 13, 2026, 10:00:35 AM
Author Topic: Stepper issue????  (Read 11028 times)
CrashMasterKev
Stepper issue????
« on: December 04, 2006, 05:12:06 PM »
I have a new machine a 24X36 tabletop with geckos and steppers and had it running pretty well,  I was running a program that I had already ran a couple times and it was fine, then I lost steps or what I believe is lost steps in the Y axis and ever since it has not worked right, my X & Z axis’s are working fine (Jogging) but the Y is still acting up, when I try to jog it will go in whatever direction it wants not necessarily the direction I choose to jog.
I swapped the Z and Y motors and that didn’t help, I swapped the Gecko drives  for those axis and no change??
I cant even home it, it just groans..
Any ideas???
Thanks in advance.
Kevin
Re: Stepper issue????
« Reply #1 on: December 04, 2006, 05:36:22 PM »
Hi Kevin,
    When you swapped the drives did you swap the blue push on connectors or leave them with the y axis? If you just pulled them off of the pin connectors and back on the other drive, rotate them 90 degrees and push on if space will permit. Does each axis have a separate power supply? Can you turn the screw for the y axis freely by hand?
« Reply #2 on: December 04, 2006, 06:25:06 PM »
Check out your wiring to make sure its all sound, also mess around a bit with your motor tuning for that axis.
