Hello Guest it is November 01, 2026, 11:52:57 AM
Author Topic: New LazyCam has lots of problems  (Read 41589 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: New LazyCam has lots of problems
« Reply #10 on: December 04, 2006, 10:02:28 PM »
Hi, Art
The last 2 ver of LC fixed the most important items for me, Thanks.
Now theres only items of less importance for me anyway.
Just trying to report items that I haxe found on more than one computer and don't function as implied
Its a dirty job, thats why we spend so-much time helping others where we can.
Ill edit my previous post to reflect what is fixed or now usable for me.
Thanks Again, Chip
« Reply #11 on: December 26, 2006, 08:29:58 AM »
Hi All,
I have just downloaded Lazycam. while try to import any dxf file I get the following error message.
MachManip MFC Application has encountered a
problem and needs to close.  We are sorry for the
inconvenience.
Error Sighnature
AppName: lazycam.exe    AppVer: 1.0.0.1    ModName: lazycam.exe
ModVer: 1.0.0.1    Offset: 001eb2
Please help
Manjeet
AGOMAGO
« Reply #12 on: January 05, 2007, 10:14:06 AM »
The same happen to me
what's the problem???
I need help.
Thanks Ago
Hi All,
inconvenience.
Error Sighnature
Please help
Manjeet
« Reply #13 on: January 06, 2007, 05:35:49 PM »
That is odd...  I will look and see how you could get that problem.
What are you running for computers?
www.newfangledsolutions.com
www.machsupport.com
AGOMAGO
« Reply #14 on: January 09, 2007, 09:14:27 AM »
 :D
Now I download new Lcam and it works..
Thank you Ago ;)
« Reply #15 on: January 11, 2007, 01:04:42 PM »
I have been posting in "G-Code, CAD, and CAM discussions" that I was having problems loading dxf files created in CorelDraw. I was wondering if you knew of any fixes for this problem ? The problem is the same when I use Coreldraw ver 7 and the newest X3 version. The DXF file that is created will import into Turbocad just fine but not Lazycam.
Thanks for any help
Offline Chip
  •  2,055 2,055
« Reply #16 on: January 11, 2007, 01:51:13 PM »
Hi, Alex
Can you export your file from Turbocad as DXF, Dose it then work in LazyCam ?
Have try-ed Corel myself, with problems also.
Chip
« Reply #17 on: January 11, 2007, 05:54:42 PM »
I created a file in Turbocad and it does not load either. It get an error message that there are no entities found. Here is the file from Turbo attached.
« Reply #18 on: January 11, 2007, 08:06:29 PM »
The file is actually only text, at least that is all I found. Text cannot be directly converted to a cut. You need to convert it to lines and curves. If Turbocad won't do this then you will need other programs to do it.
Find the program DeskEngrave or Stick Font, on the internet, to do this on the cheap. They are a little crude, but free. You can import these generated text files into Turbocad for modification or you can import them directly into LazyCam.
Bill
Pixel Tamer
Offline Chip
  •  2,055 2,055
« Reply #19 on: January 13, 2007, 10:41:47 PM »
Hi, Alex
See below, loaded it in turbocad , Exploded it then Group it under Format, resaved it as DXF
Loaded & posted with LazyCam.
Hope this helps, Chip
